Fan placement help
dryfly
118
Just built a new i7 system using a Corsair case. The case came with 2 120mm fans, front and rear. I have a 140mm fan laying around that I would like to add.
Would the most efficient use of this fan be on the top of the case or on the side (over the CPU)? In either position would sucking air into the case be better than exhaust of the air?
Ketchup
14,559
248
The top would be the best. Only caveat would be if the fan moves more air than the 120. If so, it would be best in the back IMO, as it would be a little better at pulling air across the heatsink.
dryfly
118
both places same distance from CPU heatsink, what's the difference? Not enough room for 140mm on back fan position.
Ketchup
14,559
248
If the top fan pulls more air than the back or CPU fan, it may interrupt cool air going through the cooler.
But I really recommend you test for youself and see. Part of the fun or building my own computer is trying different ways to see what cools best.
dryfly
118
With all the views thought I'd get more opinions on this one.............
No big deal I'll try a couple of case positions.
