fan placement advice.... WC
harpy82
hi all,
i need some advice on the placement of my fan on the radiator....
current setup:
radiator and fan outside the case mounted to the exhaust hole.... fan behind the radiator blowing INTO the radiator
what i am considering:
since sucking air thru the radiator is better... i plan to put my fan inside the case sucking air....
radiator and a cut hollowed fan(shroud) outside the exhaust hole.....
basically im trying to turn my exhuast into an intake.... i will use my side 90mm fan as an exhaust...
i was hoping some advice on this setup before i go about it.... i can't do anythin to my system now.. motherboard is giving vdd problem...
pleaseee anyone...
