- May 26, 2005
- 158
- 0
- 76
I have the 200 mm front fan sucking air in. 200 mm top fan blowing air out. 120 mm rear fan sucking in. I also have a hyper 212+ cooler sucking the air from the rear fan into the cooler. I don't know how to use realtemp but it seems like the minimum temp is 25C and max is 40C.
BTW, my temp seems kind of high for just browsing the web. Should I redo the cooler installation?
thanks
thanks
