Fan on mobo is dying
FlowerMan
1,324
how long has it been? It's probably just a 50mm fan, and you can splice the wires with the connector of the old fan. If it's within the warranty period, they should replace the fan. Or, you can get a blorb or something like that.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Take the fan off and throw it away. Lots of boards with Kt133 chipsets have no fan, some don't even have a heatsink. If you're terribly concerned get a zalman chipset sink from 2cooltek, or one of the small sinks from 1coolpc if you already have thermal epoxy.
cardboardbox
148
thanks for the replies... I'll look into a heatsink but in the meantime i might take the fan off and see if that makes my system unstable.
Jeff7
41,596
20
Asus would probably just send another of the cheap fans they use. I use either Tennmax Lasagna coolers on mine (got a bunch really cheap) or else something similar to the FAC08. One of mine uses a 40x40x25mm fan - that does quite a fine job. Make sure to get something not sleeve bearing though.
FlowerMan
1,324
Isnt the FAC the really thin heatsink from Global Win? Get the FA420, it beats the blorb :)
