Fan noise at a certain RPM?
Elixer
10,371
762
This is a bit odd, on a EVGA 750, the fan makes a kind of a rattle noise only at a specific RPM, which is around 43%.
If it goes lower than 43% or higher than 45%, then no odd noise comes from the fan.
I thought it might need cleaning, but, there wasn't any dust on the fan worth mentioning.
Since it just started to happen, I am assuming that the bearings might be going bad?
nerp
9,865
105
If it never made the noise until recently, then yes, one of the bearings might be on its way out.
