Fan Issue on GA-965P-S3
madara
86
My Cpu Fan keeps turning off 20-1hr into booting my new system. I hear now that Gigabyte GA 965P-S3 has this issue. It shuts off my pc and makes it hard to boot too. Any suggestions or others with thesame issue? About ready to mail this mobo back to newegg. I downloaded some F8 bios, no idea what do with it, didnt even come with readme. flash bios utility perhaps? Its been long time. On start up my bios says 6.0 something if that mattters.
Conky
10,709
I connected my heatsink fan directly to the power supply. Now it runs full blast all the time. :thumbsup:
I didn't like that weird fan activity when it was plugged into the motherboard and couldn't seem to turn it off in the bios.
madara
86
Ah I would need modulator adapters then. Im curious if changing to legacy here will fix it in bios smart fan settings.
madara
86
Flashed Bios to F8 and changed to legacy fan speed. So far so good but I have gone as long 2hrs before and it started up again. Figures crossed :) thanks for help
madara
86
Grr, tried start it up with changes today, F8 bios and legacy fan mode and now fan will not spin at all after working for 5hrs yesterday night. Im tried of this crap, its going back.
Whoaru99
21
Any chance it's the fan crapping out, not the mobo?
Mine seems to work just fine on F7 bios with the stock Intel cooler/fan using the Auto/Auto settings.
Actually, I have tried several settings and they all seem to do what they supposed to. Auto/Auto is the easiest so I left it there.
AstroGuardian
842
here is the solution.
Enter BIOS. Under System health or something similar you can check the temperatures and the fan's rpm. There is an automatic fan control option. Enable it. Then under it you should see something like what regulates the rpm speed. There are three options or so. (Auto, Voltage, PWM... not sure exactly). Try all of them. One of them WILL work. That's how i solved the problem to a customer of mine who returned the board to me.
colossus
10,873
I just bought a S3 and it's a known problem with the board (at least from the 50+ Newegg reviews I read).
Best solution would be to connect the power to a 4-pin Molex and just forget about it.
