Fan In Retail Athalon Box w/ Alpha 6035
cjhrph
104
Is the fan that comes with the retail athalon acceptable for use with my 6035 or should I spring the $15 for a different one ? My athalon should be here this week. If not, which fan should I choose ?
mechBgon
Oct 31, 1999
30,699
Is it a 60mm fan? If not, better pick one up. If you don't mind a bit of noise, the YS Tech 27cfm fan is a nice one... dual ball bearings and a long lifespan. If you want quiet, a 60mm Panaflo L1A from teamawe.com would be very quiet but at about half the airflow. How fast is your rig, anyway?
Mikewarrior2
7,132
if its a 900 athlon or higher, then the fan is fine. It should be the delta 60x10mm ~20CFM fan, and will work on the pal...
Mike
cjhrph
104
Here's what I've collected so far:
1Ghz Athalon Retail Box (In Transit)
Alpha 6035 w/o Fan
FongKai 603 w/300w power
2 x 128 Crucial CAS2 Memory
Radeon 32DDR
IBM 75GXP 45gig (In Transit)
Plexwriter 8/4/32 CDRW
Toshiba XM5702B CD
3Com905c - TXM
SB Live Value
Viewsonic PF 790
Linksys Router
Westell ADSL Modem
Altec Lansing Soundsystem
: MSI K7T Pro2a - Sold
Looking to Buy A7V133 or MSI Turbo (if its out) This week !
Mikewarrior2
7,132
yeah, the fna is fine, but you may need to get something to space out the screws(they are designed for 60x25mm fans)
Mike
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Yeh, don't cut the screws, they're hell to find. Use tubular plastic spacers above the fan. Try the shack or a hardware store.
ericd
355
Do not cut the screw whatever you do. I have looked everywhere I can think of and the only response I have ever gotten is &quot;I don't have any idea where you would get something like that&quot;. Lowe's, Home Depot, local mom &amp; pop hardware store all the same response. So if anyone does know where to get them tell me.
Eric
