ok, so i have a lian li pc65B case. it comes with four 80mm fans. on my epox 9NPA-SLI, there is a connector on the board for an extra fan, the fan i hooked up to this was the fan on to top of the case. there was another connector next to that for the CPU fan. finally with two fans left are both right next to each other in the front bottom of the case, there is a straight male 4-pin connector (rather than 2 pins on top of 2pins), and a straight female 4-pin connector. how do i hook those up to the PSU or motherboard. the case came with this wire that has a female and male connector that seem to work perfectly for the fan connectors, but on the other side are 2 small white 2 tiny prong connectors. im assuming this cable works with those two fans, but im not certain. how can i hook those 2 fans up. i dont think i have any extra fan connectors on the mobo.
cpu heatsink/fan - JCPU_Fan
Top "ceiling" fan - JPWR_Fan
Rear fan - JSYS_Fan
those "J***_Fan" things are the labels on the motherboard next to the connectors. i think the one labeled JPWR_Fan was the extra fan connector (the manual said this connector was for an extra fan if i had one). the problem is, i have 4 case fans, but only 2 fan connectors, not including the cpu fan. thanks in advance. hope i didnt make it too confusing
Rear fan - JSYS_Fan
