anyone recommend me a very good fan/heatsink for a the new opteron 165 dual corekt 939. Im using a msi k8n neo2 platinum. Im planning on overclokin. are the xp90 very good? so yeah what ones do you guys recommend?
Just browse this forum ands you will find many many threads on fans and heatsinks.....
The Big 5 in my opinion are....
Scythe Ninja
ThermalRight SI 120
ThermalRight XP 90 Copper
ThermalRight XP 120
Then I would say we have a tie at 5th between
Zalman 9500 and the Big Typhoon
Yes, the XP-90 is excellent for good cooling with low noise levels (with the right fan.) The XP-120 is better, but sadly, it is not gauranteed to fit on the K8N Neo2.
