fan for SI-120
twitchee2
Im getting a SI-120 soon. i need a fan for it. i has to be quiet thats my only thing that is a MUST. i was looking at panaflos cuz everyone uses them, but they are all loud. what quiet 120 do you sugest to use on that hsf?
This>http://www.jab-tech.com/NEXUS-120MM-REAL-SILENT-CASE-FAN-D12SL-12-pr-2856.html
if you want uber quiet. This>http://www.jab-tech.com/Coolermaster-UV...120-mm-SUF-S12-EB-UV-Blue-pr-2590.html
if $ is tight and you still want quiet. SVC has a newer 3 blade 120mm CoolerMaster fan thats spec'd out nicely thats plain black if you'd rather have black.
The YateLoons at TekGems>http://tekgems.com/Products/et-13713-fan-d12sl-12.htm are quite the deal as well starting at $6 for 2 and $4 for 5. Yate makes the Nexus fan for them at Nexus's specs. Cant go wrong with any of those for silence imo.
i well i want thinking about gettting the coolmaster clear led 120 im getting two of those for my case i could get a 3rd to put on the hs
no im not going to get a new case for a while i want to just gets things quieter now i dont have the money for a case right now
I second that!! I have 2 coolermaster fans and I can`t even hear them cranked all the way up!!
bang for the Buck Coolermaster delivers!!
2 things to note...
Thermaltake Smart fans are not accurately rated for noise....I have used them and without a fan speed controller of some kind you will never even get close to 17dba....
Also I have used the AeroCool Turbine again they are not rated accurately....
Thats one of the only reason I go with the Coolermaster...they are rated very accurately!!
Originally posted by: JEDIYoda
2 things to note...
Not sure about the turbine but doesn't the Smart Fan come with a fan controller? Without it wouldn't it run at full speed?
yes it does...come to think of it...but I ditched the fan controller in favor of using my Zalman MFC1 after trying the controller out that it came with I felt my Zalman provided lower rpms!
