Fan for Ninja?
RobDMB
Since my case lacks a side vent I've decided to go with a ninja over the big typhoon. Now my question is which fan do people recommend for this setup. My only requirement is that I want a fan that I will be able to plug into the motherboard cpu fan header. Thanks, Rob
There are many stickied reviews of this HS at the top of this page.
spcr says it doesn't need more than 40cfm. So just buy a 120x25 fan that has a sensor/tach
wire. Note that not all three wire fan have a sensor/tach wire. A BX at the end of a Panaflo
part# indicates a sensor wire.
For a high quality BB fan w/sensor get the Delta Triple Blade in 120x25. It will put out more
air than you probably need.
Yate Loons are inexpensive but I have no idea about sensor feeds on those.
Check out these fans at jab-tech.com or sidewindercomputers.com
Just for fun, check out the Akasa fans at sidewinder. The 120x25 sure looks sweet.
I have heard nothing about this fan yet......Buy one and review it for us..😀
Merry Christmas Rob..:gift:
...Galvanized
...Galvanized
:thumbsup:
Great post, and his info. is right on, IMO.
