I was just looking for some information on the pros and cons of using a few filters in front of the intake fans on my antec dragon case. There are two 80mm fans in front and neither have filters on them. What I was wondering was if I do add a 2 filters to these fans will it make an air pressure difference and not make the air flow as good as it should? Do I just need filters for the intake fans? There are 2 intake and 2 main expel and a dual ps fan sucking heat off the cpu heatsink and out of the back of the case.
Any info would be great. Running cpu temp is around 34-36 C
Regards
Regards
