Hi,
I have the Coolermaster MasterCase H500M with two 200mm fans at the front (blowing air into the case) and two 200mm fans at the top (blowing air in) and one 140mm fan at the back (blowing air out).
I also have a Noctua NH D15 which is blowing air from front to back. All fans spin at a fixed 600-650 RPM except for the CPU (800-1200) and GPU (maxes out at 2200~).
I have attached probably my best artistic work that I have ever worked on in paint depicting my case's airflow.
Is this setup okay? Or not ideal?
Appreciate any input!
