Fan Controlling and switching fans.
ShazK
Can I control more than one fan with a Zalman FanMate2 or should I just go ahead and get a Sunbeam Rheobus thing?
Do I even need to control my fans? It'll make it a lot quieter for when I'm not gaming I assume. Thanks for the help.
(I'm buying Yate Loon low and medium speed fans (120mm)). I have the Antec TriCools that came with the case, and they are good at low and medium setting, but a bit noisy at high. Should I switch all, some, or none of my fans (on my Antec P180 case)?
Thanks.
Aug 9, 2005
64
yeah, i'd go with the rheobus. you can control even more than one fan per channel if they don't require too much wattage i believe. has worked really well for me so far as it gives me total control over the fans for when i'm gaming or just idling around
