Fan Controllers
pirred908
I need to get a fan control for my 92mm Vantec Tornado HSF. Any recomendations? Most of the controllers I see out there control up to four fans, I only need it to control one. I dont want it to do much more than change the RPM, Something as simple as possible would be nice. Thank you.
P.S. Preferably Black
I believe I need a controler that can handle 18v, that one doesnt seem to. Also, I'm using the Xaser III case and I just realized a standard knob control wont allow be to close the panel door. Is there any other way? Perhaps useing one of the PCI slot doors in the back? Please help.
it needs to handle 18 watts you mean not volts... Check out www.SVC.com they have a bunch of controllers that handle 20 watts per channel. you can get one of the small ones that fits in a 3.5 floppy bay if you are looking to save space or a large 5.25 bay one that is a bit bigger.
