Fan Controllers
biggiesmallz
Banned
Feb 1, 2003
881
Are they simply plug the fan in to the fan controller? Or does it involve stripping the wire then connecting?
DannyBoy
8,820
www.danj.me
Depends which one you get.
The more simplistic ones have molex connections for your fans, where as the more case modder and customisable ones have other means of connection.
Dan
biggiesmallz
Banned
Feb 1, 2003
881
Dan
Molex meaning the 3 (I think 3) pin connector thingy that normally plugs into the motherboard?
