Fan controller?
Arctucas
Greetings to all,
I just joined after lurking for the last few weeks, wanted to say this is one of the best forums that I am subscribed to.
Anyway, my question is; could someone recommend a fan controller? I am looking for one that will fit a 5.25 drive bay and can control at least six fans (two 92mm, three 120mm, and one 250mm) with silver faceplate. Fan RPM is a necessity, temperature probes would be nice, but not required. If possible, please provide link to manufacturers website.
Sincerest regards.
When you say you want a controller with RPM monitoring, that means you're looking for something with a display, right?
MacPower DigiDoc 5 - hard to find in the US, only in black and white, but the only one I can think of that's case mounted with display, and can handle 8 channels. 12w per channel.
Sunbeam Theta - PCI card, 8 channels, software controls fan speeds and monitoring. 10w per channel.
http://www.jab-tech.com/product.php?productid=3196
-z
EDIT: nice find Jeff!
Originally posted by: Arctucas
Thanks for the links. It looks like the DigiDoc is only a monitor and the Zalman is only a controller, i guess I could use both.
The DigiDoc is a controller also. It's digital, so I'm sure it's a pain, but yes, it controls fans as well.
-z
-z
From what I gather from the manual, it looks like it has on/off functionality only, but that that functionality can be thermally controlled, as in you'd set a temperature where the fan turns on. I don't know if it can do gradual changes in fan speed.
I used to own the DigiDoc5, but I just never really used all of its functionality, and the mass of wires grew to be a bit of a pain, since I'd like to tinker with the PC's guts a bit too often. 🙂
Thanks for the info. I was hoping to find an integrated contoller/monitor, anyone else have any suggestions? Googleing isn't much help, so I am relying on input from those of you who have much more experience than I. Perhaps someone knows where I could get a custom made unit?
Check out the Sunbeam Theta that I linked earlier, software controlled PCI card (plugs into the USB header though) so you won't have to worry about color of the case or anything.
Pretty much any controller/monitor is going to have a mess of wires if you're not careful with the setup. Nature of the beast.
I haven't owned the DigiDoc, so I can say from personal experience, but yeah as far as I can tell there isn't an easy way to manually adjust fan speeds. Still, the thermal management setting should work really well.
-z
Another vote for the sunbeam theta, will have one in my "ultimate air-cooling" system as soon as it and a few other pieces finally get here.
