- Feb 19, 2001
- 20,155
- 23
- 81
I bought this fan controller to replace my dying Nexus fan controller. I really liked my old fan controller because it supported 18W per channel x 4. However 2 of the rheostats burned out or something because I can only use 2 and with my recent fan upgrades I got 4 medium RPM 120mm fans and 2 are running on the loud side.
Unfortunately for me, I have one fan on 4 pin molex connectors, so my old fan controller had a 4 => 3 pin female (dude you can't even find these on Newegg anymore wtf.. took me on a treasure hunt to buy another one of these adapters), and consequentially you lose RPM sensing. Another fan, my Panaflo 120x120x38 for my CPU has only 2 wires (3 pin connector) so it has no RPM sensing. My 3rd fan I can't really tell but I believe it's a Yate Loon like my first fan so it's also a 4 pin molex => 3 pin.
Either way, these 3 fans when plugged into my fan controller power up briefly (5 sec or so) and then turn off. I know these fans run under 0.5 A (more like 0.3A) and the fan controller can take 1A per channel. I don't see how it could use too much power. After all they started up for a few secs.
My knowledge tells me these aren't PWM fan controllers (right??? PWM = 4 pin small connectors) and are voltage fan controllers. However something tells me that RPM wire matters. Why did I get these ghetto fans without RPM sensing?!?!?!?
Here's the final clue. 4th fan is a new Zalman ZM-F3 to replace my whining Antec case fan. RPM sensing 3 pin with 3 wires! It turns on, and the RPM shows up. I can dial it up or down. Most importantly, it STAYS on.
I don't give a damn about RPM readings. I just want my fans to be able to be controlled. I don't see why this voltage based fan controller can't do this. Am I missing something about the product here?
Anyone recommend me a fan controller? I've always known about the Sunbeam ones but those LEDs are blinding and I don't want a laser light show at night.
I could either get a new fan controller, but I'm wondering if power is an issue too? Or is RPM sensing required in almost all fan controllers now? Why can't they make something simple! GRRRrrrrr... My other option is to go buy some new fans. Petras Tech Shop is literally like 10 min from my work so I can drop by and pick up 2 new Yate Loons for a price less than my dinner, but then I'll have fans lying around doing no good in my house.
