Fan controller/Temp Monitoring unit
Burner27
Can any recommend a unit like the DigiDoc5+ that controls fan speed and monitors temperatures?
I give the example of the DigiDoc5+ so you all know what I am looking for, but if there is anything better please recommend it.
Thank you.
i'm looking for something like this too if anyone has a suggestion, but i only need a fanbus/rheostat. need to control 2xfans on 2 channels plus 1 on a third channel (5 fans total). that's all i need, no temp stuff. sunbeam made one that would work but it's discontinued. not sure if the other ones i've seen can handle this without problems. would also like 3pin connectors for the fans (i have splitters already).
if you just want to control fan speed, there are a lot of cheap controllers out there. it's really a question of how fancy you want your controller to be. the more bells and whistles, the more you pay. but in the end...most likely, all thats really doing the work is some cheapo trim-pot 🙂
that digidoc5 u pointed out seems to cost 80 bucks when i froogled it...definitely NOT worth the money for such simple functionality
