I could use some suggestions for what people have used as a fan controller. I will be getting (most likely) the P160 so something that matches that case (silver) is a priority. In the case I will have 3 fans. The P160 already comes with two (I belive two) temperature sensors so I can monitor temperature inside the case.
Here are my thoughts right now: I need a fan controller for 3 fans, it would be nice if it would automatically increase speed if heat increased to a certain temperature, but still allow me to set what I want it to be at default. Therefore, it probably needs temperature sensors. Other then that, just want to be able to control my fan speeds and monitor temperature inside my case. The fans I'm getting are these:
http://www.compusa.com/products/product_info.asp?product_code=318489&pfp=BROWSE
It doesn't tell me what kind of connection pin it has.
I did find this particular one, don't know too much about it though:
http://www2.newegg.com/Product/Product.asp?Item=N82E16813999903
