- Dec 10, 2013
- 92
- 0
- 61
I want to make sure I understand this correctly...
This controller...
Lamptron FC-8
Says it is 30W per 8 Channels... My new case, the Switch 810, will someday have 15 fans... 6 at the top with Rad, 4 on bottom with Rad, 2 in front, 2 on hard drive casing, and 1 rear fan. And the Cougar fans I want are rated at 14 watts.
So...
If I link the push pull fans together in pairs, (That's 10 fans, 6 top, 4 bot) and connect each pair to a channel, that's 28W so that's good to go...
Then pair the two front fans, and the two HDD case fans to two separate channels, that's another 28W (Not sure what there are actually called, they are the adjustable fans like dead center of the case that can be angled)
Then the last rear fan just connect to it's own channel...
That's 8 channels, with 15 fans, 7 channels at 28W... Is this all correct math etc or am I missing something...
This controller...
Lamptron FC-8
So...
