Fan controller for Wave Master case
996GT2
5,212
I'm looking at a fan controller to control the 4 fans in my Wave Master (2 80mm front, 1 80mm rear, 120mm side). But after looking at a lot of them I realized that many of them probably wouldn't allow the door to close fully. Anyone know of good fan controllers under $30 that will fit the Wavemaster? 3.5 or 5.25 bay, it doesn't matter, as long as it has 4 channels at maybe an LCD display.
Also anyone have thougnts on me cutting the front section of the Wavemaster with the intake holes completely out and leaving 2 open rectangles there?
996GT2
5,212
Thanks everyone...I cut out the middle portions of the front panel to improve airflow, and the task took about 1.5 hours due to the extremely thick aluminum. Used 3 cutting wheels and a whole bunch of sanding drums. Will post pictures later after I do the side 120mm mod
Zepper
18,998
The Aerogate 3 was designed because the earlier models wouldn't fit behind the Wavemaster's door.
.bh.
