Fan controller and P180
lupin3rd
Hey,
I have an Antec P180 and I'm using the Antec fans that were included. The only thing is that I have to open the case in order to change the fan speeds. Unless there is a way to place the switches somewhere reachable from the outside, I'd have to look into a fan controller.
Which fan controller will fit with the rail system to mount into the 5.25" bay?
Help would be appreciated!
Hey yourself! 😀
I do not have this case. Those that do would be well advised to go to silentpcreview.com.
On the left, cases and damping? Click on it. There you will find not one but three reviews
of this case. Much you will need to know will be found there.
...Galvanized
I have this one and while only one screw goes into the drive rail, it fits wonderfully in the case. It just sucks that there is only one 3.5" bay on the front of the case.
Hmmm...I'll look into the Zalman ZM-MFC1 if there is no fitting issues with the mounting rails. I'd rather get a 5.25" since there is only 1 3.5" bay which I have occupied. Also I'm not impressed with the 3.5" Vantec Nexus since I used it on another computer and it didn't make an audible difference when turning the knobs.
