Hey everyone I need some help. I am putting together a system, but this is my first time using one of those variable fan speed controllers. The controller has 4 variable fans speed knobs. In this system I will have a cpu fan, a hard drive cooling fan, 2 fans in the front of the case, 2 fans in the rear of the case, and then there is the side fan, which is mounted on my case's side panel. On the Asus A8V Deluxe motherboard that I am using there are connections for a CPU_FAN, PWR_FAN, and CHA_FAN. I know the cpu's fan will go to the CPU_FAN connection. What do you suggest I connect to the PWR_FAN and CHA_FAN connection? Should I not use those since I am using a fan controller? I am using a thermaltake fan controller which monitors system temperature as well. I'm guessing I will use the fron 2 fan for intake, and the side and read fans as exhaust. Any input would be helpful. Thanks in advance.
