1Dogg2RuleAll
Background: I am in the middle of building a system that is to be a nice compromise between power and silence. I have a question when it comes to fans and fan controllers. My motherboard will only control one fan (the cpu fan). I am trying to control 2 other fans so that occassionally I can crank it up on rpm speed, but typically will have it very low. I understand computers and most parts well, but it is the first time I have turned my attention this way towards fans and fan control...
Question: What fans can be controlled? Must they specifically state "PWM" or do they have to have a specific "connector". What is the difference between a 4 pin and 3 pin connector in regards to control if any?
Don't ask about system specs as that is irrelevant as I am asking the above question and not a question on my specific system. (I get annoyed when so many, in so many forums try to be an expert and state regurgitated info on a system,... so understand, if you can answer the question then system specs are meaningless)
