I am doing my first build, and I have what seems like a noob question.
The fans that come with the P180 Case have what appear to be standard 4 pin connectors, but it looks like only 2 of the pins are actually used (ground and power).
The chassis fan conectors on the P5B MoBo have THREE pins, labelled Ground, power, and "rotation". I assume Rotation is the way that the fan would tell the Mobo its rotation speed. the Antec case fans seem to lack this third wire. Am I correct?
What is the correct way to connect the 4 pin connector from the fan onto the 3 pin conector on the Mobo? From the diagrams on the mobo manual it would seem that if I simply plug the 4 pin conenctor onto the 3 pin connector to line up the power and ground pins on both connectors, the ground and power pins would be reversed. I assume this can be easily corrected by fliiping the fan over, but I don't know if there are any other consequences.
If there is anyone with this same Mobo/case combination, could you please let me know how you connected your fans to the MoBo?
