- Feb 12, 2007
- 14
- 0
- 0
I have a what has turned out to be a "major problem" with my new fan control system.
Firstly my case is the Antec Nine Hundred which has 4 fans (one 20cm!) with normal LP4 connectors.
Rather than having to change fan speeds manually (each fan has a three-way switch) I decided to get an mCubed T-Balancer to do the job for me (this unit is getting good reviews everywhere).
Here's where the problem starts - the power output from the T-Balancer is via Tx3 male connectors and the fans (as I have already said) are LP4 (male).
Searching google I can find adaptors which allow Tx3 fans to be run from an LP4 connector but nothing which is the exact opposite. What I need is an adaptor which is female Tx3 on one end and a female LP4 on the other.
Any help would be appreciated (URLs for example). Please don't tell me I have to get out the soldering iron and knock some up myself, these old eyes aren't what they used to be
Thankz
KG
Thankz
KG
