I cut a hole in the MB tray, behind the cpu socket, then cut a hole above that in my case side panel and put an 80mm panaflo L1A there. So the fan blows on the back of the MB behind the socket. Reading temps in bios after running prime95 for an hour, its now at 44C, down from 49C.
I'm pretty sure that checking temps in bios is the only way to read off the diode with an nf7. If the reading were off the socket, then these results would be worthless because then maybe I am just cooling the pcb and not the cpu at all.
