fan blowing direction
cmt9000
43
Ok, I was going to title this post 'suck or blow', but thought that might get me banned for life.
Anyway....I have a 92mm fan that I want to attach to my VGA card's aftermarket heatsink(HR-3).
Should I have the fan moving air OFF the heatsink(sucking) or ON the heatsink(blowing).
thanks
cmt9000
43
Ok....
A Platinum member says suck air off....
A Senior member says blow air on....
Now I'm really confused. :)
Deinonych
633
If you look at the Zalman HSFs (for procs or GPUs), you'll note that the fans blow onto the heatsink. You need the airflow to aid in heat dissipation.
Post count has nothing to do with it. :)
aCynic2
710
You know, I've owned computers all the way back to the 80s, when the top of the line was an XT. When the HS/Fan came out to cool CPUs (I think around the 486 era), they've always blown *on* the HS.
I really haven't seen manufacturers make them any other way, at least I've not seen the majority of manufacturers design them any other way.
Noubourne
751
Why don't you try both and tell us the temp differences?
I would bet it's less than a couple degrees.
The reason many fans point down toward a mobo is to take advantage of the airflow by helping to remove some heat from the area surrounding the CPU which otherwise would not get much airflow at all. Since PWM is located around there and tends to be pretty hot, this was a side benefit.
Of course, PWM doesn't really need to be that cool...
I doubt it has much affect if any on the CPU that you are cooling whether you push or pull, unless the added airflow in the area helps to push some other heat away that might have otherwise built up around the CPU area.
In the case of water cooling, there is often a radiator outside the system, and the only purpose of airflow is to remove heat from the radiator, and so there is no consideration of side benefits like overall case airflow or additional component cooling. Users often find that push/pull makes no difference. Pull is often selected because they find it causes less air turbulence and thus is quieter.
Generally people want their GPU cooler fans pointing at the video card in order to take advantage of the airflow by cooling off the RAM too. Of course, that heatsink can be mounted on the BACK of the card in one configuration, which may negate any benefits that you might have got by pointing the fan at the RAM as well.
And then of course, there's the question of how useful it is to cool the RAM. At stock speeds, if it's not overheating, I'd venture to say there's no reason to cool it at all.
So you see some reasons why you might get answers going both ways on this...
graysky
796
@cmt9000 you have to do the experiment and report back to us. Just run orthos or if you have a C2D run several orthos for say 15 min with the fan sucking an report the temps you get in TAT. Switch the direction of the fan and do the same. Let's settle this with some data.
soydios
2,708
Blow down onto the heatsink. That way, the airflow moving out from the heatsink across the card also cools the components around the core/socket.
gorobei
3,957
1,443
older H/S designs are not the massive towers we have now, so the old theory was to blow air down thru the vanes onto the processor and get some air moving over the rest of the motherboard components. New H/S towers attempt to push/pull air in an east to west direction (front of case to back of case) The main thing being to get the hot air out and away from the critical location as fast as possible.
Most of the reviews of CPU H/S like the Thermalright 120 split on whether push or pull is better. Each reviewer has temp numbers indicating one over the other and viceversa. Heatpipes work pretty well with any sort of temp differential, so it shouldnt make to much of a difference.
In the interest of optimization tho,
It kinda depends on how you mounted the HR-3. radiator on top, or bottom
TOP mount: since your HR-3 has heatpipes to transfer heat to the radiator fins on the other side(top) of the videocard, blowing down("on" in your terms) isn't likely to help cool the rest of the card (specifically the memory chips) Since most of the air you would be blowing down would come from the CPU, it would be warmer than the air surrounding the card. So I would recommend sucking the air up("off" in your terms) At least this way you have a better chance of pulling some cool air from the side panel vents and your exhaust fans + cpu H/S +PSU fans can take the hot air away faster.
BOTTOM mount: blow down "on" to the radiator since the side panel vents will provide the coolest air possible.
Herradura
137
I have a similar question.. I just got a Arctic freezer 7 pro and it has only lowered my temps by 4-5c in load and full. I wwas expecting better results from this cooler so I was wondering did I install the HSF in the correct direction? should the fan be facing the RAM?, the GPU?, the back fan? or the up, the PSU? As you can tell I didnt get instructions with my cooler so any help would be great :)
cmt9000
43
Thanks for the hijack....j/k
I have the same CPU cooler. Mine is facing the front of my case, sucking the air in towards the HS because I have a 120mm exhaust fan right behind it. So it sucks in the air, through the HS, and then is blown right out the back of the case.
