I'm buying a new PSU and am confused as to the location of the larger fans in the PSU. Some appear to be at the top, where airflow is often restricted or non-existent; others at the bottom, which seems to me the obvious position. None of the manufacturers' sites address this issue.
Are there any relevant standards, does a top-mounted fan require a specific case with an airflow channel above the PSU, or are the PSUs simply reversible and can be used in either orientation?
Thanks for all replies.
