Fan airflow direction
wallrunnerm15
170
i can't tell which direction the air is blowing in my thermaltake fan. there are no direction arows either. can anyone help me?
JBDan
2,333
With most fans, if you are looking at the label/sticker in the middle, it is blowing towards you..... if the label/sticker can be seen (on a rear-mounted exhaust fan) as your looking at the back of your case's exhaust, its blowing out. Was that confusing? lol
SketchMaster
3,100
149
The way you put it? Yes.
The fan will (almost) always blow down. or the part that holds the blade/motor in place. meaning that if you are looking at the fan like This then the fan will blow towards you.
