- Jan 9, 2000
- 791
- 1
- 81
HI
Does anyone make adaptors to use on case fans??
In particular, I want to replace the 80mm fans on my Antec sx840 with the 4 92mm panaflo's I bought. The room on the back of the case is very limited. The 92mm's will fit with some major cutting. If a adaptor was made, maybe this would be easier to use as I would like to keep the case intact if I can. (That's a big if!!)
I posted under this Antec sx840 and 92mm fans and got a good amout of info that has helped me.
When I read a few posts about adaptors for cpu coolings fans, my curiosity got the best of me.
Thanks
Pghpooh
Thanks
Pghpooh
