I have an 80mm cpu fan that uses a 4pin peripheral type connector. I would like to use a 3pin converter to plug into the mobo so the bios can controll the RPMs. Does anybody know if that would work the way I want it to? Also, the fan has a max amp draw of .45 amps but would probably operate at half that most of the time, would that be acceptable to run of the mobo connector?
Thanks
jason
Thanks
jason
