- Dec 15, 2015
- 17,569
- 16,942
- 146
I have an in-line water pump (one of many) in a radiant heat system that appears to be nonfunctional. I hear whirring (louder than it should be), it's vibrating/indicating moving parts which varies correctly with the speed dial on it (low/med/high) but it never appears to actually push hot water through the output pipe. Pump gets hot, nothing on the pipes though.
We recently had a pretty catastrophic water breach while we were out of town, so the pump was potentially running dry for a while, several hours at minimum, a day or two at maximum. I know that's super Not Great for those pumps so I won't be surprised to know it's borked, but curious if anyone's seen this and recovered before. Other pumps are fine, I bled the line in case it was air locked (was air in the line), but nada otherwise. My bleed port isn't isolated to that pump so I had water moving from more than that source.
