Hi,
I am still using Win-7.
I have a HDD where I have saved Win-7 with all settings & Updates till 2020.
I use this HDD in case if I need to install win-7 in another drive by just cloning new HDD from this HDD.
I was cloning a new SSD from this HDD to install win-7 from this old HDD but I got a message halfway when cloning as follows :
" Failed to read from sector " 100 003 656 " from HDD-1. Try to repeat but if error persist use chkdsk.
Direct R/W operation has failed. ( Ox 590001 ).
Input/Output error ( OXFFF1 ) "
It gave me a choice to try again or ignore or ignore all.
I selected " Ignore all " and it installed Win-7 on new SSD.
Windows-7 is working fine on New SSD.
Should I continue to use it & install all my apps & data on this newly cloned SSD or run chkdsk on original HDD ? & then install Win-7 again ?
Couple of my important apps seems to be working fine on this new SSD.
Please advice.
Thank You.
Please advice.
Thank You.
