Fail build is fail. Screw up at work.
Locut0s
22,205
44
I'm a little new to recommending system builds to people and made a mistake at work the other day. I put together a system for a customer (who was having a friend build it for him) which consisted of an athlon X3 CPU, mobo and RAM. The rest of the components he was going to recycle from his old build. Unfortunately I neglected to notice that the CPU was AM2 and the mobo was AM3. He took it home and his friend put it together but the system would continually just shut off and on. He brought it back and of course what had happened is that when they installed the CPU in the (incorrect) socket the socket had sheered off some of the pins on the CPU. Luckily my manager seems to have taken it mostly well, not that he was happy of course. I'm not nearly as used to AMD systems as Intel systems. Oh well that certainly won't happen again. :oops::oops:
lxskllr
60,007
10,500
That's why pros build with Intel :^P
Fuck it, live and learn. Anyone who says they don't make mistakes at work is either lying, or unchallenged :^)
BoomerD
66,260
14,690
Geezus...I hope you're better at this than you are at driving...(or spelling) :p
Locut0s
22,205
44
Yeah. While I'm knowledgeable enough about computers I have only put together a few of my own systems and while I read up on tech on a daily basis it's a different mater when dealing with the details of specific components. The devil is in the details of course. I'll learn as I go.
Newbian
24,779
882
cus he chose the wrong cpu for the motherboard
Yea, I saw that after reading it again.
Fixed it to be true but seriously how does one not know it doesn't fit these days.
Slot A does not fit component B unless you jam it in hard enough.
I guess the person never did a jigsaw puzzle.
zerocool84
36,041
472
Well I give them the benefit of the doubt cus AM2 and AM3 look so similar.
Locut0s
22,205
44
This. It was my fuckup for recommending the wrong board. However the two socket types are similar enough that one can fairly easily force one CPU into the other socket type. I think AMD should have changed the packaging a little more to make it even harder for this to happen.
Locut0s
22,205
44
I used to work at home depot and people returning some things, you'd just wonder how they got them attached.
Would be fun to hear some stories from the returns counter at IKEA.
Customer: "Umm yeah I bought this china hutch but it doesn't hold any dishes! I WANT MY MONEY BACK!"
You: "WTF How did you build a helicopter with that!?"
Ancalagon44
3,274
202
When I built my new PC at the beginning of this year, I bought an AM3 board and an Athlon II 620. I installed the CPU - with the lever in the down position. And couldnt get it out.
I should have left it there, but instead I tried for a few hours to get it out. I finally did, with a small screwdriver, but noticed I had now bent the pins. So, I tried to straighten them with a credit card. Ended up breaking 2 or 3 off. So I bought a new one. Yes, massive waste of money. At least it wasnt a Phenom II 965!
What are the chances of it still working? And, if it is broken, what are the chances of it causing permanent damage to another component such as the motherboard? Just wondering if its worth seeing if I cant do something with it other than using it as a paper weight.
lxskllr
60,007
10,500
It depends on which pins you broke. I've heard of cpus running fine missing pins.
Locut0s
22,205
44
How did you manage to install it with the lever in the down position? I wouldn't think the pins would even fit in the socket let alone make contact. I doubt there is much you can do with it. It's not exactly something you can solder back on.
jackace
1,307
Sorry to hear that OP we all make mistakes from time to time.
Not sure why the person installing the CPU was forcing it in place. This person must have had a bad day or was inexperienced, because I don't know anyone who forces a CPU into place. If it doesn't just drop into place something is wrong, and you should find out what it is and fix it not force it.
Ancalagon44
3,274
202
Dont worry about it mate. Shit happens. move on. Forget about it.
Yeah, that was months ago. I replaced it with another one and havent looked back. However, I still have it, and my friend is using an Athlon X2 5600 +. If he could get a free upgrade to a 620, it would be pretty cool for him.
Uh I just put it in. I think I then raised and lowered the lever, and that secured the CPU in such a way that it could not be removed. Cant remember exactly but it was something like that.
So yeah, next time I made sure to raise the lever first!
zCypher
6,115
171
I bent some pins once when I was but a wee lad, it was one of them PS/2 connectors and I didn't bother looking to see how I was plugging it in. So after fumbling it for a while I look at the connector and see these bent pins. lol
I learned my lesson about bending pins with that at a young age... Haven't had a problem since. Always been somewhat paranoid about CPUs too, so I've been careful.
Numenorean
4,442
You're obviously NOT knowledgeable enough about computers.
AyashiKaibutsu
9,306
4
Wish I could get a job doing stuff that I didn't really even have the basics down for. No seriously like someone hire me at a physics think tank or something; it'd be fun : ) That probably sounds harsher than I want it, but seriously getting the right socket is pretty much as basic as things get.
