Fact or Crap? Does setting these two bcdedit to True for Win7/8 improve gaming?
Crow550
2,381
Been Googling about this. The answers seem rather mixed....
If you run Command Prompt in Admin mode and type in these two commands:
bcdedit /set useplatformclock true (First make sure HPET/ACPI is enabled in BIOS)
bcdedit /set disabledynamictick true
then reboot
It can help reduce Latency? (Some cases may do the opposite too)
This worth tweaking or leaving them both on False?
Dankk
5,558
25
I wouldn't recommend messing around with critical system settings unless you absolutely know what you're doing.
Dahak
3,752
25
To be honest I do not know either, but according to MSDN they should only be used for debugging, and usually would not enabling something for debugging incur more latency ranter then reduce it
plus the 2nd one only works on 8/2k12
