I am shocked we can't tell where it is and drop a smart bomb on it.
Unless we wanted them to capture it...
Again, the military had operations in motion to capture and/or destroy it and Obama called them off. He thought asking nicely and using the magic word would work.
How the fuck does it seem "fake"?
I'm sick and tired of government officials, they should just come out and say whether it happened or not.
No one will give a shit anyways.
My question is, why aren't these things equipped with 5 pounds of C4 that goes off if certain safety parameters are violated or also triggerable by its operators?
Exclusive: Iran hijacked US drone, says Iranian engineer
Pretty smart. I hope some of the guys and gals over at the CIA and Lockheed Martin (?) are doing some face palms over this.
Merry Xmas to Iran, Russia, China, etc.
The last footage that was captured by the drone after it went down, was an Iranian soldier teabagging the camera on said drone.
Obummer must have raged quit after that - LULZ!!!!shift+1!!!
If the drone was hacked and Iran had complete control, how is the operator going to trigger a self destruct?
It could be kept on a completely different circuit from the rest of the systems. It could passively monitor the telemetry but be hardwired such that hacking can't interact with it. If it sees confusing info from the telemetry, boom. If the operator loses contact, he triggers destruction. Lots of other ways.
"The GPS navigation is the weakest point," the Iranian engineer told the Monitor, giving the most detailed description yet published of Iran's "electronic ambush" of the highly classified US drone. "By putting noise [jamming] on the communications, you force the bird into autopilot. This is where the bird loses its brain."
The “spoofing” technique that the Iranians used – which took into account precise landing altitudes, as well as latitudinal and longitudinal data – made the drone “land on its own where we wanted it to, without having to crack the remote-control signals and communications” from the US control center, says the engineer.
The revelations about Iran's apparent electronic prowess come as the US, Israel, and some European nations appear to be engaged in an ever-widening covert war with Iran, which has seen assassinations of Iranian nuclear scientists, explosions at Iran's missile and industrial facilities, and the Stuxnet computer virus that set back Iran’s nuclear program.
Now this engineer’s account of how Iran took over one of America’s most sophisticated drones suggests Tehran has found a way to hit back. The techniques were developed from reverse-engineering several less sophisticated American drones captured or shot down in recent years, the engineer says, and by taking advantage of weak, easily manipulated GPS signals, which calculate location and speed from multiple satellites.
As a sidenote:
As an electrician with a little bit of RF background :
The plain will land when the communication is lost yes ?
What if the Iranians where able to find out at what frequencies communications between the drone and the command center where taking place ? Would it then not be possible to send out a high power signal directed at the receiving frequency for the drone. Then the drone will no longer receive any commands because the receiver inside the drone will not be able to decode commands properly and assume communication was lost.
It is similar as that you whisper to me and another person starts shouting next to you. I will not be able to hear you and i have to assume lost communication.
But even then, i would assume the drone would fly back to a preprogrammed set of coordinates (GPS) and land outside enemy territory behind friendly borders. If this is not the case, then that is a huge design flaw.
I would think the drone malfunctioned or the drone has design flaws.
No, Obama PWNED the CIA when he called off any attempts to recover/blow up the drone once it crashed hopping that "pretty please" would work.
Its all made in Taiwan.
That would be awesome if it were true...
