- Mar 3, 2000
- 50,129
- 781
- 126
2009
When turning the 4X4 switch, the dash shows the correct selected range and I can feel and hear something mechanical happening.
At times it sounds like a skipping chain. But 4X4 does not engage in 4X4 low or high.
What I've done:
I replaced the vacuum solenoid as it was cheap, no help.
Troubleshooting steps:
Had the wife drive in a snowy field as I watched the front tires. They never engaged.
With both front wheels off the ground and the truck running in park:
2H - neither front axle spins when rolling the tires forward or backwards.
4H - Left axle does not turn while spinning tire in either direction.
Right axle does not spin while rotating the tire forward. But, the axle does rotate when spinning the tire backwards.
What's next?
What I've done:
What's next?
