i recently re-fired up my p2 400 back into the fray(slow but yet it makes deadlines although by 1-2 days)
as of now it seems to have problems sending the completed WU
i am naturally quite worried since the deadline is in about 1.5 days time
so i copied the whole folder to the main rig and fired it up with the -send all arguement.....
yet the console reports that it can't send the WU
i've checked server stats and most of them are up
[14:13:06] + Attempting to send results
[14:13:07] Working on Unit 09 [March 30 14:13:07]
[14:13:07] + Working ...
[14:13:10] Folding@Home Client Core Version 2.47 (June 14, 2002)
[14:13:10]
[14:13:10] Proj: work/wudata_09
[14:13:10] Done: 22972 -> 142973 (decompressed 622.3 percent)
[14:13:11] nsteps: 5000000 dt: 2.000000 dt_dump: 250.000000 temperature: 298.000000
[14:13:11] xyzfile:
[14:13:11] " 393 p638_L939_K12M_ext
[14:13:11] 1 N -2.298497 -55.257436 68.097214 20..."
[14:13:11] keyfile:
[14:13:11] "parameters ./proj638.prm
[14:13:11] NOVERSION
[14:13:11] ARCHIVE
[14:13:11]
[14:13:11] cutoff 16.0
[14:13:11] taper 12...."
[14:13:11]
[14:13:11] - Couldn't get size info for dyn file: work/wudata_09.dyn
[14:13:11] Starting from initial work packet
[14:13:11]
[14:13:11] Protein: p638_L939_K12M_ext
[14:13:11] - Run: 262 (Clone 71, Gen 33)
[14:13:11] - Frames Completed: 0, Remaining: 400
[14:13:11] - Dynamic steps required: 5000000
[14:13:11]
[14:13:11] Writing local files:
[14:13:11]
[14:13:11] parameters work/wudata_09.prm
[14:13:11] - Writing "work/wudata_09.key": (overwrite) successful.
[14:13:11] - Writing "work/wudata_09.xyz": (overwrite) successful.
[14:13:12] - Writing "work/wudata_09.prm": (overwrite) successful.
[14:13:16] - Writing "work/wudata_09.key": (append) successful.
[14:13:16]
[14:13:16] PROJECT="work/wudata_09", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=298.00
[14:13:16] TINKER: Software Tools for Molecular Design
[14:13:16] Version 3.8 October 2000
[14:13:16] Copyright (c) Jay William Ponder 1990-2000
[14:13:16] portions Copyright (c) Michael Shirts 2001
[14:13:16] portions Copyright (c) Vijay S Pande 2001
[14:17:26] - Couldn't send HTTP request to server
[14:17:26] + Could not connect to Work Server (results)
[14:17:26] (171.67.89.152:8080)
[14:17:26] - Error: Could not transmit unit 08 (completed March 30). Keeping unit in queue.
