Originally posted by: BlackMountainCow
You have to run two instances in two separate folder to really use the two CPUs at once. Either two CLIs in separate folders or one CLI and one GUI, but still in separate folders. That's the only way.
:beer:😀:beer:
Originally posted by: DaFinn
Maybe I'm stoopid, but I could not find from the client a setting to make it use both processors. Currently it's using only 1. Or does it not use 2 processors???
Originally posted by: Insidious
52 days sounds like you are confusing the deadline for completion with the estimated time of completion.
When I do a work unit with a deadline of 52 days, it usually takes ~3 days to complete.
-Sid
-Sid
Sid has it right!
In F@H each WU is created from the one before it. I think it is a sequential simulation, so the WUs need a deadline otherwise it would take too long to finish the sequence.
If you look at the Currently Running Projects you will see two deadlines. The Preferred (days) is the number of days before the WU will be re-issued to another cruncher. The Final deadline (days) is the number of days before you start losing points (I think). A 500Mhz (slower probably, I don't know) computer can finish before the Final deadline.
On my dual rig I don't set affinity. Windows XP Pro does it just fine 😀
Originally posted by: MaskedAvenger
I just switched over from SETI @ Home to Folding @ Home. With SETI, I could set affinity on each instance of S@H that I was running and it would stay set until the PC was re-booted. With F@H, affinity seems to be reset each time a WU is finished. I'm using 3 HT PC's, one of which is dual Xeon, and am using both the Home and Pro versions of XP. Someone mentioned that there was a program on Toms hardware to set affinity, but my search turned up nada. My question is this: does someone know how to automatically set affinity, and could someone feed my cat next weekend?
Originally posted by: bluestrobe
I tried to install 2 instances of F@H graphical with different folder name and it was a no go. I guess i'll be reading up on tomshardware when I wake up.
edit: hopefully it isn't too confusing as this is a server that has other uses.![]()
