F@H problem
Ghost
297
Checked on both of my machines this morning, and they were both errored out. Looks like they had just completed a WU. Rebooted both, the one I re-checked had errored out again.
Running the F@H 4.0 Screensaver client. Thought maybe I had to upgrade to the 5.0 client, but I don't see a 5.0 Screensaver client available, only for the gui/command line whatever....
Any suggestions?
3chordcharlie
9,859
What does the log file say?
They may be having trouble sending the WU back, or getting a new one.
ProviaFan
14,993
Yes, as Charlie says, if you could post your log file (FAHLog.txt), we might be able to diagnose the problem a bit more easily. :)
r0tt3n1
1,086
The v5 client has the screensaver built in to the GUI client. But, if you are using Windows 98, Stanford recommends you use the v4 CLI client instead. Are you overclocking your machines? That could cause errors. As the others have asked, please post the last 20 lines or so of your FAHLog.txt file so we can have a look see.
Ghost
297
I'm at work atm, so I can't post the log file. Will do so when I get home. Running XP Pro on both...
Running them at stock speeds...
Ghost
297
Just tried to rerun it, here's the last 70 or so lines of my log file...
[22:00:57] Loaded queue successfully.
[22:00:57] Initialization complete
[22:00:57] + Benchmarking ...
[22:01:00]
[22:01:00] + Processing work unit
[22:01:00] Core required: FahCore_65.exe
[22:01:00] Core found.
[22:01:00] Working on Unit 03 [August 23 22:01:00]
[22:01:00] + Working ...
[22:01:00] Folding@Home Client Core Version 2.53 (June 29, 2004)
[22:01:00]
[22:01:00] Proj: work/wudata_03
[22:01:00] Done: 18642 -> 160417 (decompressed 860.5 percent)
[22:01:00] nsteps: 2500000 dt: 2.000000 dt_dump: 100.000000 temperature: 305.000000
[22:01:00] xyzfile:
[22:01:00] "222 p12 p1224_A21nat99ps_gbsa305K
[22:01:00] 1 CT 10.319000 23.382000 7.34900..."
[22:01:00] keyfile:
[22:01:00] "NOVERSION
[22:01:00] ARCHIVE
[22:01:00] integrate stochastic
[22:01:00] friction 91.0
[22:01:00] RATTLE ..."
[22:01:00]
[22:01:00] Hashes matched on file work/wudata_03.dyn
[22:01:00] ARC file integrity verified
[22:01:00] Restarting from checkpointed files.
[22:01:00]
[22:01:00] Protein: p1224_A21nat99ps_gbsa305K
[22:01:00] - Run: 2 (Clone 96, Gen 0)
[22:01:00] - Frames Completed: 470, Remaining: 30
[22:01:00] - Dynamic steps required: 150000
[22:01:00]
[22:01:00] Writing local files:
[22:01:00]
[22:01:00] parameters work/wudata_03.prm
[22:01:00] - Writing "work/wudata_03.key": (overwrite) successful.
[22:01:01] - Writing "work/wudata_03.xyz": (overwrite) successful.
[22:01:01] - Writing "work/wudata_03.prm": (overwrite) successful.
[22:01:01] - Writing "work/wudata_03.key": (append) successful.
[22:01:01]
[22:01:01] PROJECT="work/wudata_03", NSTEPS=150000, DT=2.0000, DTDUMP=10.000000, TEMP=305.00
[22:01:01] TINKER: Software Tools for Molecular Design
[22:01:01] Version 3.8 October 2000
[22:01:01] Copyright (c) Jay William Ponder 1990-2000
[22:01:01] portions Copyright (c) Michael Shirts 2001
[22:01:01] portions Copyright (c) Vijay S Pande 2001
3chordcharlie
9,859
According to your log file, it's done 470 of 500 steps.
Open it up again, and see if it has added a few lines at the bottom.
Ghost
297
Opened it again. Screensaver is up for a second, then it generates one of those "FAH blah blah has generated an error, do you want to send it to Microsoft..."
[22:26:48] - Ask before connecting: No
[22:26:48] - User name: ghostedone (Team 198)
[22:26:48] - User ID = CFF8A6463F57F0B
[22:26:48] - Machine ID: 1
[22:26:48]
[22:26:49] Loaded queue successfully.
[22:26:49] Initialization complete
[22:26:49] + Benchmarking ...
[22:26:51]
[22:26:51] + Processing work unit
[22:26:51] Core required: FahCore_65.exe
[22:26:51] Core found.
[22:26:51] Working on Unit 03 [August 23 22:26:51]
[22:26:51] + Working ...
[22:26:51] Folding@Home Client Core Version 2.53 (June 29, 2004)
[22:26:51]
[22:26:51] Proj: work/wudata_03
[22:26:51] Done: 18642 -> 160417 (decompressed 860.5 percent)
[22:26:51] nsteps: 2500000 dt: 2.000000 dt_dump: 100.000000 temperature: 305.000000
[22:26:51] xyzfile:
[22:26:51] "222 p12 p1224_A21nat99ps_gbsa305K
[22:26:51] 1 CT 10.319000 23.382000 7.34900..."
[22:26:51] keyfile:
[22:26:51] "NOVERSION
[22:26:51] ARCHIVE
[22:26:51] integrate stochastic
[22:26:51] friction 91.0
[22:26:51] RATTLE ..."
[22:26:51]
[22:26:51] Hashes matched on file work/wudata_03.dyn
[22:26:52] ARC file integrity verified
[22:26:52] Restarting from checkpointed files.
[22:26:52]
[22:26:52] Protein: p1224_A21nat99ps_gbsa305K
[22:26:52] - Run: 2 (Clone 96, Gen 0)
[22:26:52] - Frames Completed: 470, Remaining: 30
[22:26:52] - Dynamic steps required: 150000
[22:26:52]
[22:26:52] Writing local files:
[22:26:52]
[22:26:52] parameters work/wudata_03.prm
[22:26:52] - Writing "work/wudata_03.key": (overwrite) successful.
[22:26:52] - Writing "work/wudata_03.xyz": (overwrite) successful.
[22:26:52] - Writing "work/wudata_03.prm": (overwrite) successful.
[22:26:53] - Writing "work/wudata_03.key": (append) successful.
[22:26:53]
[22:26:53] PROJECT="work/wudata_03", NSTEPS=150000, DT=2.0000, DTDUMP=10.000000, TEMP=305.00
[22:26:53] TINKER: Software Tools for Molecular Design
[22:26:53] Version 3.8 October 2000
[22:26:53] Copyright (c) Jay William Ponder 1990-2000
[22:26:53] portions Copyright (c) Michael Shirts 2001
[22:26:53] portions Copyright (c) Vijay S Pande 2001
Ghost
297
Uninstalled the screensaver 4.0 client on the other system. Re-booted. Re-installed. Same error. That log file is here...
[22:39:30] - Ask before connecting: No
[22:39:30] - User name: ghostedone (Team 198)
[22:39:30] - User ID = 4BCA741910292F7E
[22:39:30] - Machine ID: 1
[22:39:30]
[22:39:30] Loaded queue successfully.
[22:39:30] Initialization complete
[22:39:30] + Benchmarking ...
[22:39:33]
[22:39:33] + Processing work unit
[22:39:33] Core required: FahCore_65.exe
[22:39:33] Core found.
[22:39:33] Working on Unit 09 [August 23 22:39:33]
[22:39:33] + Working ...
[22:39:33] Folding@Home Client Core Version 2.53 (June 29, 2004)
[22:39:33]
[22:39:33] Proj: work/wudata_09
[22:39:34] Done: 21737 -> 158845 (decompressed 730.7 percent)
[22:39:34] nsteps: 2500000 dt: 2.000000 dt_dump: 100.000000 temperature: 305.000000
[22:39:34] xyzfile:
[22:39:34] " 264 p12 p1207_Fsden94pp_gbsa305K
[22:39:34] 1 CT 24.406891 9.326843 41.25..."
[22:39:34] keyfile:
[22:39:34] "NOVERSION
[22:39:34] ARCHIVE
[22:39:34] integrate stochastic
[22:39:34] friction 91.0
[22:39:34] RATTLE ..."
[22:39:34]
[22:39:34] Hashes matched on file work/wudata_09.dyn
[22:39:34] ARC file integrity verified
[22:39:34] Restarting from checkpointed files.
[22:39:34]
[22:39:34] Protein: p12 p1207_Fsden94pp_gbsa305K
[22:39:34] - Run: 2 (Clone 90, Gen 2)
[22:39:34] - Frames Completed: 97, Remaining: 403
[22:39:34] - Dynamic steps required: 2015000
[22:39:34]
[22:39:34] Writing local files:
[22:39:34]
[22:39:34] parameters work/wudata_09.prm
[22:39:34] - Writing "work/wudata_09.key": (overwrite) successful.
[22:39:34] - Writing "work/wudata_09.xyz": (overwrite) successful.
[22:39:34] - Writing "work/wudata_09.prm": (overwrite) successful.
[22:39:36] - Writing "work/wudata_09.key": (append) successful.
[22:39:36]
[22:39:36] PROJECT="work/wudata_09", NSTEPS=2015000, DT=2.0000, DTDUMP=10.000000, TEMP=305.00
[22:39:36] TINKER: Software Tools for Molecular Design
[22:39:36] Version 3.8 October 2000
[22:39:36] Copyright (c) Jay William Ponder 1990-2000
[22:39:36] portions Copyright (c) Michael Shirts 2001
[22:39:36] portions Copyright (c) Vijay S Pande 2001
Ghost
297
The reason I went with the screensaver client, is because I want it to run when I'm not at my pc. Can I configure the 5.0 client/gui that way? So that it only runs when I'm away from my pc?
3chordcharlie
9,859
I think that's built-in to version 5.
Both of your log files look fine; the core seems to be engaging.
Check back in a couple of hours and see if it has finished any frames.
r0tt3n1
1,086
Per chance have you changed video drivers recently? If so, roll them back, or, keep the newer vid drivers and download the v5 GUI which has the screensaver built in, and give it a go.
Something else we can look at, there is a file named FAHLog-Prev.txt, maybe we could have a peek at the end of that log to possibly help figure out what the heck is going on.....
Ghost
297
Only change I did to primary system was to install the Demo for Exigo, and I did get an "out of signal" error one time when I relaunched that. But that's it. No new video card drivers in a while. The other system hasn't had anything installed on it for a few weeks. Weird both would error out at the same time. Here's from the fahlog-prev log....
Gonna download 5 and see what that does..
[21:54:33] - Ask before connecting: No
[21:54:33] - User name: ghostedone (Team 198)
[21:54:33] - User ID = CFF8A6463F57F0B
[21:54:33] - Machine ID: 1
[21:54:33]
[21:54:34] Loaded queue successfully.
[21:54:34] Initialization complete
[21:54:34] + Benchmarking ...
[21:54:36]
[21:54:36] + Processing work unit
[21:54:36] Core required: FahCore_78.exe
[21:54:36] Core found.
[21:54:36] Working on Unit 02 [August 21 21:54:36]
[21:54:36] + Working ...
[21:54:36]
[21:54:36] *------------------------------*
[21:54:36] Folding@home Gromacs Core
[21:54:36] Version 1.65 (May 6, 2004)
[21:54:36]
[21:54:36] Preparing to commence simulation
[21:54:36] - Looking at optimizations...
[21:54:36] - Files status OK
[21:54:37] - Expanded 1287904 -> 6672285 (decompressed 518.0 percent)
[21:54:38]
[21:54:38] Project: 724 (Run 6, Clone 14, Gen 14)
[21:54:38]
[21:54:38] Assembly optimizations on if available.
[21:54:38] Entering M.D.
[21:54:58] (Starting from checkpoint)
[21:54:58] Protein: p724_Abeta21-43-amberGS
[21:54:58]
[21:54:58] Writing local files
[21:54:58] Completed 23750 out of 125000 steps (19)
[21:54:59] Extra SSE boost OK.
Folding@home Client Shutdown.
Ghost
297
Downloaded 5.0 client. Have it set to run as screensaver when system is inactive, and it seems to be working fine. Thanks for the effort guys.
Ghost
297
Ooops?
Went to the F@H forum. Looks like I'm not the only one having problems. Also, can't get the screensaver option in version 5 to work either, others have posted about that problem as well on the F@H forums.... no fixes yet...
GLeeM
7,199
128
Sorry about the Oops, :confused: I had a bunch of questions, then edited them out and put in the Oops. It takes me a loooooong time to think and post :)
Did you see anything there about a way of using Task Scheduler to start F@H with a Task Scheduler setting of only run when the system is not being used?
Ghost
297
No, I didn't see anything about Task Scheduler. It's something to consider.
But it sounds like the 5.0 client is buggy in regards to the screensaver option within it. Several others have reported that problem, so hopefully they'll get it fixed, and that will be it.
