Originally posted by: Tetsuo316
Well, now I'm using KDFold and that's nice and all except I can't figure out how to configure the program proerly. I would like to launch KDFold at startup and have it launch the client automatically. I don't see this option in the program.
Do I need to run the client as a service and just launch KDFold at startup?
First of all, we don't officially discourage the use of FoldingSpy, it's just that neither of the two of us who have seen this thread know how to use it. Perhaps I'll set it up in VMWare under a virtual OS to try to figure out how it works; maybe then I can help you.
Now, to have KDFold launch at startup, you must put a shortcut to it in your "Startup" folder under "Programs" in the start menu. KDFold will not start the client automatically (it's specialty is monitors tons of clients either locally - as on a SMP machine - or on a network, or both), so you'll also have to put a shortcut to the client in your Startup folder. Unfortunately, this will leave the client running in the taskbar as a large button (that's one reason you would probably be better off with FoldingSpy). An advantage to running the client as a service would be to have it running even when you're not logged in (in Windows 2000 and XP), and to have it out of the taskbar, but that requires an additional utility called Firedaemon, and is a bit complex to set up. If you do want to proceed down that path, LMK and I'll try to help you out (I've done it before so I'm familiar with the process, and there is a helpful guide also located somewhere on the net - if only I can find it
If you do prefer FoldingSpy, feel free to go back to using that, but you may need to get help with it over at the
FoldingCommunity forums because none of us seem to know how to fix it.
