F@H - Need Help <UPDATE-FIXED>
ICXRa
I have posted about issues with F@H in jliechty's daily stats thread and tried several things but nothing seems to be happening.
Rebel Alliance has 3 machines crunching F@H yet it's often times days/weeks between showing any results. Currently it has been nearly a week since any thing has showed up in the daily stats yet standford shows the date of the last work unit as 4-15-03.
The machines are:
2 -1.5 celery laptops that run the client but these are not always on and 1-P4 2.4 GHZ that runs 24 X 7. It is the P4 that really should be pushing out most of the work as this box will do 8 seti WU's a day but I pulled it off seti to run F@H. The P4 box has had the graphic client running on it then the cli and currently I have it loaded as a service currently but it just doesn't seem to be sending in results. I have found this box; when using the gui client, spend over two weeks on a wu. I have checked everything I know to and task manager always shows 99% cpu on the F@HCore. Does anybody have any ideas of something else I could try before I give up on this? I could possibly be expecting more production that is realistic but since I am new(er) to this project I'm just not sure what to expect.
Thanks
a couple of things:
Have you looked at FAHLog.txt, to see if anything is actually happening?
Can you publish, or have you already published which Protein you are folding, so we can look at what some expected result times might be?
(I have a few machines running, so I might be able to see what my machines are doing on a given protein vs what you are doing).
You could also post the section of the FAHlog.txt that you are currently working on, so we might be able to see something.
As mgpaulus says, please post the log - before you do that make the client print the queue information (right click for the GUI, not sure about the others). When the client prints the queue info, it also gets written into the log. Probably best to just post one log to start with, as they can be rather long - post the whole thing, and possibly the "prev" log too.
I checked on your stats page and you have only 1 active CPU in the past week. This may not be a problem - if those Celerys are only on during working hours and they are crunching 70 point TINKERs they may not complete 1 in a week. (I have a PII 300 that has been crunching a 33 point GROMACS WU for over 12 days now, and that's 24x7!)
Let's get you working - you have some nice machines and we need all the help we can get!
ps. Some other things we may need to check:
Name misspellings - there is only 1 "Rebel_Alliance" in Folding's user database. Have you spelt it with a space character on any of your machines?
Have you checked your team designation too? I notice you have some under "no team" - are they from before joining TeamAnandtech? They won't show up in Josh's stats.
If you can post the log, as the other have suggested, that would be helpful. Also, open a command prompt, go to the directory that contains your FAHconsole.exe (you needn't stop the service for this; type something like cd \program files\folding@home\), and run fah3console -queueinfo to see if it reports some units that are done. If so, type fah3console -send all to attempt to send the units manaully.
--- Opening Log file [April 15 12:26:37]
# Windows Console Edition #####################################################
Folding@home Client Version 3.24
http://foldingathome.stanford.edu
email:help@foldingathome.stanford.edu
Arguments: -service
[12:26:37] - Ask before connecting: No
[12:26:37] - User name: Rebel Alliance (Team 0)
[12:26:37] - User ID = 4FDA1091029525C6
[12:26:37] - Machine ID: 1
[12:26:37]
[12:26:38] Loaded queue successfully.
[12:26:38] + Benchmarking ...
[12:26:40]
[12:26:40] + Processing work unit
[12:26:40] Core required: FahCore_65.exe
[12:26:40] Core found.
[12:26:40] Working on Unit 04 [April 15 12:26:40]
[12:26:40] + Working ...
[12:26:40] Folding@Home Client Core Version 2.47 (June 14, 2002)
[12:26:40]
[12:26:40] Proj: work/wudata_04
[12:26:40] nsteps: 500000 dt: 2.000000 dt_dump: 100.000000 temperature: 281.000000
[12:26:40] xyzfile:
[12:26:40] " 675 p720_ABeta17-42
[12:26:40] 1 N -22.875084 1.875428 -2.909019 20 ..."
[12:26:40] keyfile:
[12:26:40] "#parameters ./opls.prm
[12:26:40] #verbose
[12:26:40] NOVERSION
[12:26:40] ARCHIVE
[12:26:40]
[12:26:40] #cutoff 16.0
[12:26:40] #taper ..."
[12:26:40]
[12:26:41] Hashes matched on file work/wudata_04.dyn
[12:26:41] ARC file integrity verified
[12:26:41] Restarting from checkpointed files.
[12:26:41]
[12:26:41] Protein: p720_ABeta17-42
[12:26:41] - Run: 46 (Clone 32, Gen 2)
[12:26:41] - Frames Completed: 38, Remaining: 62
[12:26:41] - Dynamic steps required: 310000
[12:26:41]
[12:26:41] Writing local files:
[12:26:41]
[12:26:41] parameters work/wudata_04.prm
[12:26:41] - Writing "work/wudata_04.key": (overwrite) successful.
[12:26:42] - Writing "work/wudata_04.xyz": (overwrite) successful.
[12:26:42] - Writing "work/wudata_04.prm": (overwrite) successful.
[12:26:42] - Writing "work/wudata_04.key": (append) successful.
[12:26:42]
[12:26:42] PROJECT="work/wudata_04", NSTEPS=310000, DT=2.0000, DTDUMP=10.000000, TEMP=281.00
[12:26:43] TINKER: Software Tools for Molecular Design
[12:26:43] Version 3.8 October 2000
[12:26:43] Copyright (c) Jay William Ponder 1990-2000
[12:26:43] portions Copyright (c) Michael Shirts 2001
[12:26:43] portions Copyright (c) Vijay S Pande 2001
[12:41:17] Finished a frame (39)
[12:55:38] Finished a frame (40)
[13:10:03] Finished a frame (41)
[13:24:33] Finished a frame (42)
[13:38:57] Finished a frame (43)
[13:53:17] Finished a frame (44)
[14:07:43] Finished a frame (45)
Folding@home Client Shutdown.
--- Opening Log file [April 15 14:26:54]
Arguments: -service
[14:26:54] - Ask before connecting: No
[14:26:54] - User name: Rebel Alliance (Team 0)
[14:26:54] - User ID = 4FDA1091029525C6
[14:26:54] - Machine ID: 1
[14:26:54]
[14:26:54] Loaded queue successfully.
[14:26:54] + Benchmarking ...
[14:26:57]
[14:26:57] + Processing work unit
[14:26:57] Core required: FahCore_65.exe
[14:26:57] Core found.
[14:26:57] Working on Unit 04 [April 15 14:26:57]
[14:26:57] + Working ...
[14:26:58] Folding@Home Client Core Version 2.47 (June 14, 2002)
[14:26:58]
[14:26:58] Proj: work/wudata_04
[14:26:58] nsteps: 500000 dt: 2.000000 dt_dump: 100.000000 temperature: 281.000000
[14:26:58] xyzfile:
[14:26:58] " 675 p720_ABeta17-42
[14:26:58] 1 N -22.875084 1.875428 -2.909019 20 ..."
[14:26:58] keyfile:
[14:26:58] "#parameters ./opls.prm
[14:26:58] #verbose
[14:26:58] NOVERSION
[14:26:58] ARCHIVE
[14:26:58]
[14:26:58] #cutoff 16.0
[14:26:58] #taper ..."
[14:26:58]
[14:26:58] Hashes matched on file work/wudata_04.dyn
[14:27:00] ARC file integrity verified
[14:27:00] Restarting from checkpointed files.
[14:27:00]
[14:27:00] Protein: p720_ABeta17-42
[14:27:00] - Run: 46 (Clone 32, Gen 2)
[14:27:00] - Frames Completed: 45, Remaining: 55
[14:27:00] - Dynamic steps required: 275000
[14:27:00]
[14:27:00] Writing local files:
[14:27:00]
[14:27:00] parameters work/wudata_04.prm
[14:27:00] - Writing "work/wudata_04.key": (overwrite) successful.
[14:27:01] - Writing "work/wudata_04.xyz": (overwrite) successful.
[14:27:01] - Writing "work/wudata_04.prm": (overwrite) successful.
[14:27:02] - Writing "work/wudata_04.key": (append) successful.
[14:27:02]
[14:27:02] PROJECT="work/wudata_04", NSTEPS=275000, DT=2.0000, DTDUMP=10.000000, TEMP=281.00
[14:27:02] TINKER: Software Tools for Molecular Design
[14:27:02] Version 3.8 October 2000
[14:27:02] Copyright (c) Jay William Ponder 1990-2000
[14:27:02] portions Copyright (c) Michael Shirts 2001
[14:27:02] portions Copyright (c) Vijay S Pande 2001
[14:41:33] Finished a frame (46)
[14:56:06] Finished a frame (47)
[15:10:24] Finished a frame (48)
[15:24:49] Finished a frame (49)
[15:39:05] Finished a frame (50)
[15:53:21] Finished a frame (51)
[16:07:39] Finished a frame (52)
[16:21:59] Finished a frame (53)
[16:36:15] Finished a frame (54)
[16:50:30] Finished a frame (55)
[17:04:46] Finished a frame (56)
[17:19:01] Finished a frame (57)
[17:33:17] Finished a frame (58)
[17:47:32] Finished a frame (59)
[18:01:53] Finished a frame (60)
[18:16:08] Finished a frame (61)
[18:30:25] Finished a frame (62)
[18:44:40] Finished a frame (63)
[18:58:56] Finished a frame (64)
[19:13:12] Finished a frame (65)
[19:27:27] Finished a frame (66)
[19:41:42] Finished a frame (67)
[19:56:03] Finished a frame (68)
[20:10:19] Finished a frame (69)
[20:24:43] Finished a frame (70)
[20:39:02] Finished a frame (71)
[20:53:18] Finished a frame (72)
[21:07:33] Finished a frame (73)
[21:21:49] Finished a frame (74)
[21:36:04] Finished a frame (75)
[21:50:25] Finished a frame (76)
[22:04:41] Finished a frame (77)
[22:18:56] Finished a frame (78)
[22:33:12] Finished a frame (79)
[22:47:27] Finished a frame (80)
[23:01:43] Finished a frame (81)
[23:15:58] Finished a frame (82)
[23:30:19] Finished a frame (83)
[23:44:35] Finished a frame (84)
[23:58:50] Finished a frame (85)
[00:13:06] Finished a frame (86)
[00:27:21] Finished a frame (87)
[00:41:37] Finished a frame (88)
[00:55:53] Finished a frame (89)
[01:10:09] Finished a frame (90)
[01:24:24] Finished a frame (91)
[01:38:47] Finished a frame (92)
[01:53:05] Finished a frame (93)
[02:07:20] Finished a frame (94)
[02:21:36] Finished a frame (95)
[02:35:51] Finished a frame (96)
[02:50:07] Finished a frame (97)
[03:04:22] Finished a frame (98)
[03:18:38] Finished a frame (99)
[03:32:59] Finished a frame (100)
[03:32:59] TINKER is Exiting following Normal Termination
[03:32:59]
[03:32:59] Finished Work Unit:
[03:32:59] ARC file integrity verified
[03:32:59] logfile size: 20480
[03:32:59] Leaving Run
[03:33:01] - Writing 468854 bytes of core data to disk.
[03:33:01] end (WriteWorkResults)
[03:33:01] - Shutting down core
[03:33:01]
[03:33:01] Folding@Home2 Core Shutdown: FINISHED_UNIT
[03:33:04] CoreStatus = 64 (100)
[03:33:04] Sending work to server
[03:33:04] + Attempting to send results
[03:33:06] + Results successfully sent
[03:33:06] Thank you for your contribution to Folding@home.
[03:33:06] + Number of Units Completed: 24
[03:33:10] + Attempting to get work packet
[03:33:10] - Connecting to assignment server
[03:33:11] - Successful: assigned to (171.64.122.124).
[03:33:11] + News From Folding@Home: Welcome to Folding@Home
[03:33:11] Loaded queue successfully.
[03:33:15] + Closed connections
[03:33:15]
[03:33:15] + Processing work unit
[03:33:15] Core required: FahCore_78.exe
[03:33:15] Core found.
[03:33:15] Working on Unit 05 [April 16 03:33:15]
[03:33:15] + Working ...
[03:33:16]
[03:33:16] *------------------------------*
[03:33:16] Folding@home Gromacs Core
[03:33:16] Version 1.43 (March 4, 2003)
[03:33:16]
[03:33:16] Preparing to commence simulation
[03:33:16] - Looking at optimizations...
[03:33:16] - Created dyn
[03:33:16] - Files status OK
[03:33:16] - Expanded 348807 -> 1760993 (decompressed 504.8 percent)
[03:33:16] - Starting from initial work packet
[03:33:16]
[03:33:16] Project: 542 (Run 42, Clone 23, Gen 7)
[03:33:16]
[03:33:16] Assembly optimizations on if available.
[03:33:16] Entering M.D.
[03:33:23] Protein: p542_BBA5_N in water
[03:33:23]
[03:33:23] Writing local files
[03:33:25] Writing local files
[03:33:25] Completed 0 out of 500000 steps (0)
[03:40:05] Writing local files
[03:40:05] Completed 5000 out of 500000 steps (1)
[03:46:46] Writing local files
[03:46:46] Completed 10000 out of 500000 steps (2)
[03:53:26] Writing local files
[03:53:26] Completed 15000 out of 500000 steps (3)
[04:00:07] Writing local files
[04:00:07] Completed 20000 out of 500000 steps (4)
[04:06:47] Writing local files
[04:06:47] Completed 25000 out of 500000 steps (5)
[04:13:27] Writing local files
[04:13:27] Completed 30000 out of 500000 steps (6)
[04:20:07] Writing local files
[04:20:07] Completed 35000 out of 500000 steps (7)
[04:26:47] Writing local files
[04:26:47] Completed 40000 out of 500000 steps (8)
[04:33:28] Writing local files
[04:33:28] Completed 45000 out of 500000 steps (9)
[04:40:07] Writing local files
[04:40:07] Completed 50000 out of 500000 steps (10)
[04:46:47] Writing local files
[04:46:47] Completed 55000 out of 500000 steps (11)
[04:53:28] Writing local files
[04:53:28] Completed 60000 out of 500000 steps (12)
[05:00:07] Writing local files
[05:00:07] Completed 65000 out of 500000 steps (13)
[05:06:53] Writing local files
[05:06:53] Completed 70000 out of 500000 steps (14)
[05:13:34] Writing local files
[05:13:34] Completed 75000 out of 500000 steps (15)
[05:20:13] Writing local files
[05:20:13] Completed 80000 out of 500000 steps (16)
[05:26:53] Writing local files
[05:26:53] Completed 85000 out of 500000 steps (17)
[05:33:34] Writing local files
[05:33:34] Completed 90000 out of 500000 steps (18)
[05:40:14] Writing local files
[05:40:14] Completed 95000 out of 500000 steps (19)
[05:46:56] Writing local files
[05:46:56] Completed 100000 out of 500000 steps (20)
[05:53:37] Writing local files
[05:53:37] Completed 105000 out of 500000 steps (21)
[06:00:18] Writing local files
[06:00:18] Completed 110000 out of 500000 steps (22)
[06:06:58] Writing local files
[06:06:58] Completed 115000 out of 500000 steps (23)
[06:13:38] Writing local files
[06:13:38] Completed 120000 out of 500000 steps (24)
[06:20:20] Writing local files
[06:20:20] Completed 125000 out of 500000 steps (25)
[06:27:00] Writing local files
[06:27:00] Completed 130000 out of 500000 steps (26)
[06:33:41] Writing local files
[06:33:41] Completed 135000 out of 500000 steps (27)
[06:40:21] Writing local files
[06:40:21] Completed 140000 out of 500000 steps (28)
[06:47:01] Writing local files
[06:47:01] Completed 145000 out of 500000 steps (29)
[06:53:42] Writing local files
[06:53:42] Completed 150000 out of 500000 steps (30)
[07:00:29] Writing local files
[07:00:29] Completed 155000 out of 500000 steps (31)
[07:07:09] Writing local files
[07:07:09] Completed 160000 out of 500000 steps (32)
[07:13:49] Writing local files
[07:13:49] Completed 165000 out of 500000 steps (33)
[07:20:31] Writing local files
[07:20:31] Completed 170000 out of 500000 steps (34)
[07:27:12] Writing local files
[07:27:12] Completed 175000 out of 500000 steps (35)
[07:33:53] Writing local files
[07:33:53] Completed 180000 out of 500000 steps (36)
[07:40:33] Writing local files
[07:40:33] Completed 185000 out of 500000 steps (37)
[07:47:14] Writing local files
[07:47:14] Completed 190000 out of 500000 steps (38)
[07:53:55] Writing local files
[07:53:55] Completed 195000 out of 500000 steps (39)
[08:00:38] Writing local files
[08:00:38] Completed 200000 out of 500000 steps (40)
[08:07:19] Writing local files
[08:07:19] Completed 205000 out of 500000 steps (41)
[08:14:00] Writing local files
[08:14:00] Completed 210000 out of 500000 steps (42)
[08:20:40] Writing local files
[08:20:40] Completed 215000 out of 500000 steps (43)
[08:27:21] Writing local files
[08:27:21] Completed 220000 out of 500000 steps (44)
[08:34:02] Writing local files
[08:34:02] Completed 225000 out of 500000 steps (45)
[08:40:44] Writing local files
[08:40:44] Completed 230000 out of 500000 steps (46)
[08:47:25] Writing local files
[08:47:25] Completed 235000 out of 500000 steps (47)
[08:54:13] Writing local files
[08:54:13] Completed 240000 out of 500000 steps (48)
[09:00:54] Writing local files
[09:00:54] Completed 245000 out of 500000 steps (49)
[09:07:35] Writing local files
[09:07:35] Completed 250000 out of 500000 steps (50)
[09:14:17] Writing local files
[09:14:17] Completed 255000 out of 500000 steps (51)
[09:20:59] Writing local files
[09:20:59] Completed 260000 out of 500000 steps (52)
[09:27:39] Writing local files
[09:27:39] Completed 265000 out of 500000 steps (53)
[09:34:19] Writing local files
[09:34:19] Completed 270000 out of 500000 steps (54)
[09:40:59] Writing local files
[09:40:59] Completed 275000 out of 500000 steps (55)
[09:47:40] Writing local files
[09:47:40] Completed 280000 out of 500000 steps (56)
[09:54:21] Writing local files
[09:54:21] Completed 285000 out of 500000 steps (57)
[10:01:04] Writing local files
[10:01:04] Completed 290000 out of 500000 steps (58)
[10:07:45] Writing local files
[10:07:45] Completed 295000 out of 500000 steps (59)
[10:14:28] Writing local files
[10:14:28] Completed 300000 out of 500000 steps (60)
[10:21:10] Writing local files
[10:21:10] Completed 305000 out of 500000 steps (61)
[10:27:52] Writing local files
[10:27:52] Completed 310000 out of 500000 steps (62)
[10:34:40] Writing local files
[10:34:40] Completed 315000 out of 500000 steps (63)
[10:41:22] Writing local files
[10:41:22] Completed 320000 out of 500000 steps (64)
[10:48:03] Writing local files
[10:48:03] Completed 325000 out of 500000 steps (65)
[10:54:45] Writing local files
[10:54:45] Completed 330000 out of 500000 steps (66)
[11:01:26] Writing local files
[11:01:26] Completed 335000 out of 500000 steps (67)
[11:08:07] Writing local files
[11:08:07] Completed 340000 out of 500000 steps (68)
[11:14:48] Writing local files
[11:14:48] Completed 345000 out of 500000 steps (69)
[11:21:29] Writing local files
[11:21:29] Completed 350000 out of 500000 steps (70)
[11:28:10] Writing local files
[11:28:10] Completed 355000 out of 500000 steps (71)
[11:35:13] Writing local files
[11:35:13] Completed 360000 out of 500000 steps (72)
[11:41:55] Writing local files
[11:41:55] Completed 365000 out of 500000 steps (73)
[11:48:35] Writing local files
[11:48:35] Completed 370000 out of 500000 steps (74)
[11:55:16] Writing local files
[11:55:16] Completed 375000 out of 500000 steps (75)
[12:01:57] Writing local files
[12:01:57] Completed 380000 out of 500000 steps (76)
[12:08:38] Writing local files
[12:08:38] Completed 385000 out of 500000 steps (77)
[12:15:20] Writing local files
[12:15:20] Completed 390000 out of 500000 steps (78)
[12:22:01] Writing local files
[12:22:01] Completed 395000 out of 500000 steps (79)
[12:28:50] Writing local files
[12:28:50] Completed 400000 out of 500000 steps (80)
[12:35:31] Writing local files
[12:35:31] Completed 405000 out of 500000 steps (81)
[12:42:12] Writing local files
[12:42:12] Completed 410000 out of 500000 steps (82)
[12:48:53] Writing local files
[12:48:53] Completed 415000 out of 500000 steps (83)
[12:55:33] Writing local files
[12:55:33] Completed 420000 out of 500000 steps (84)
[13:02:14] Writing local files
[13:02:14] Completed 425000 out of 500000 steps (85)
[13:08:57] Writing local files
[13:08:57] Completed 430000 out of 500000 steps (86)
[13:15:39] Writing local files
[13:15:39] Completed 435000 out of 500000 steps (87)
[13:22:19] Writing local files
[13:22:19] Completed 440000 out of 500000 steps (88)
[13:28:59] Writing local files
[13:28:59] Completed 445000 out of 500000 steps (89)
[13:35:39] Writing local files
[13:35:39] Completed 450000 out of 500000 steps (90)
[13:42:20] Writing local files
[13:42:20] Completed 455000 out of 500000 steps (91)
[13:49:00] Writing local files
[13:49:00] Completed 460000 out of 500000 steps (92)
[13:55:40] Writing local files
[13:55:40] Completed 465000 out of 500000 steps (93)
[14:02:25] Writing local files
[14:02:25] Completed 470000 out of 500000 steps (94)
[14:09:05] Writing local files
[14:09:05] Completed 475000 out of 500000 steps (95)
[14:15:48] Writing local files
[14:15:48] Completed 480000 out of 500000 steps (96)
[14:22:44] Writing local files
[14:22:44] Completed 485000 out of 500000 steps (97)
[14:29:26] Writing local files
[14:29:26] Completed 490000 out of 500000 steps (98)
[14:36:08] Writing local files
[14:36:08] Completed 495000 out of 500000 steps (99)
[14:42:52] Writing local files
[14:42:52] Completed 500000 out of 500000 steps (100)
[14:42:54] Writing final coordinates.
[14:42:54] Past main M.D. loop
[14:43:54]
[14:43:54] Finished Work Unit:
[14:43:54] - Reading up to 1025436 from "work/wudata_05.arc": Read 1025436
[14:43:54] - Reading up to 0 from "work/wudata_05.xtc": Read 0
[14:43:54] goefile size: 0
[14:43:54] logfile size: 28745
[14:43:54] Leaving Run
[14:43:58] - Writing 1061293 bytes of core data to disk...
[14:43:58] ... Done.
[14:43:58] - Shutting down core
[14:43:58]
[14:43:58] Folding@home Core Shutdown: FINISHED_UNIT
[14:44:01] CoreStatus = 64 (100)
[14:44:01] Sending work to server
[14:44:01] + Attempting to send results
[14:44:06] + Results successfully sent
[14:44:06] Thank you for your contribution to Folding@home.
[14:44:06] + Number of Units Completed: 25
[14:44:10] + Attempting to get work packet
[14:44:10] - Connecting to assignment server
[14:44:10] - Successful: assigned to (171.64.122.143).
[14:44:10] + News From Folding@Home: Welcome to Folding@Home
[14:44:10] Loaded queue successfully.
[14:44:11] + Closed connections
[14:44:11]
[14:44:11] + Processing work unit
[14:44:11] Core required: FahCore_65.exe
[14:44:11] Core found.
[14:44:11] Working on Unit 06 [April 16 14:44:11]
[14:44:11] + Working ...
[14:44:11] Folding@Home Client Core Version 2.47 (June 14, 2002)
[14:44:11]
[14:44:11] Proj: work/wudata_06
[14:44:11] Done: 24459 -> 148247 (decompressed 606.1 percent)
[14:44:11] nsteps: 2000000 dt: 2.000000 dt_dump: 100.000000 temperature: 323.000000
[14:44:11] xyzfile:
[14:44:11] " 473 p659_1PRB_NAT
[14:44:11] 1 CH3 8.775540 4.032773 -18.164073 7 ..."
[14:44:11] keyfile:
[14:44:11] "parameters ./proj659.prm
[14:44:11] NOVERSION
[14:44:11] ARCHIVE
[14:44:11]
[14:44:11] cutoff 16.0
[14:44:11] taper 12...."
[14:44:11]
[14:44:11] - Couldn't get size info for dyn file: work/wudata_06.dyn
[14:44:11] Starting from initial work packet
[14:44:11]
[14:44:11] Protein: p659_1PRB_NAT
[14:44:11] - Run: 11 (Clone 36, Gen 1)
[14:44:11] - Frames Completed: 0, Remaining: 400
[14:44:11] - Dynamic steps required: 2000000
[14:44:11]
[14:44:11] Writing local files:
[14:44:11]
[14:44:11] parameters work/wudata_06.prm
[14:44:11] - Writing "work/wudata_06.key": (overwrite) successful.
[14:44:12] - Writing "work/wudata_06.xyz": (overwrite) successful.
[14:44:12] - Writing "work/wudata_06.prm": (overwrite) successful.
[14:44:12] - Writing "work/wudata_06.key": (append) successful.
[14:44:12]
[14:44:12] PROJECT="work/wudata_06", NSTEPS=2000000, DT=2.0000, DTDUMP=10.000000, TEMP=323.00
[14:44:13] TINKER: Software Tools for Molecular Design
[14:44:13] Version 3.8 October 2000
[14:44:13] Copyright (c) Jay William Ponder 1990-2000
[14:44:13] portions Copyright (c) Michael Shirts 2001
[14:44:13] portions Copyright (c) Vijay S Pande 2001
[14:48:11] Finished a frame (1)
[14:52:09] Finished a frame (2)
[14:56:08] Finished a frame (3)
[15:00:07] Finished a frame (4)
[15:04:07] Finished a frame (5)
[15:08:06] Finished a frame (6)
[15:12:05] Finished a frame (7)
[15:16:04] Finished a frame (8)
[15:20:04] Finished a frame (9)
[15:24:04] Finished a frame (10)
[15:28:03] Finished a frame (11)
[15:32:03] Finished a frame (12)
[15:36:09] Finished a frame (13)
[15:40:08] Finished a frame (14)
[15:44:06] Finished a frame (15)
[15:48:05] Finished a frame (16)
[15:52:04] Finished a frame (17)
[15:56:04] Finished a frame (18)
[16:00:02] Finished a frame (19)
[16:04:00] Finished a frame (20)
[16:07:59] Finished a frame (21)
[16:11:57] Finished a frame (22)
[16:15:55] Finished a frame (23)
[16:19:52] Finished a frame (24)
[16:23:49] Finished a frame (25)
[16:27:46] Finished a frame (26)
[16:31:41] Finished a frame (27)
[16:35:36] Finished a frame (28)
[16:39:33] Finished a frame (29)
[16:43:31] Finished a frame (30)
[16:47:28] Finished a frame (31)
[16:51:28] Finished a frame (32)
[16:55:26] Finished a frame (33)
[16:59:25] Finished a frame (34)
[17:03:25] Finished a frame (35)
[17:07:29] Finished a frame (36)
[17:11:28] Finished a frame (37)
[17:15:27] Finished a frame (38)
[17:19:25] Finished a frame (39)
[17:23:24] Finished a frame (40)
[17:27:23] Finished a frame (41)
[17:31:21] Finished a frame (42)
[17:35:19] Finished a frame (43)
[17:39:47] Finished a frame (44)
[17:44:39] Finished a frame (45)
[17:48:37] Finished a frame (46)
[17:52:35] Finished a frame (47)
[17:56:33] Finished a frame (48)
[18:00:31] Finished a frame (49)
[18:04:30] Finished a frame (50)
[18:08:28] Finished a frame (51)
[18:12:27] Finished a frame (52)
[18:16:26] Finished a frame (53)
[18:20:25] Finished a frame (54)
[18:24:24] Finished a frame (55)
[18:28:24] Finished a frame (56)
[18:32:21] Finished a frame (57)
[18:36:20] Finished a frame (58)
[18:40:18] Finished a frame (59)
[18:44:18] Finished a frame (60)
[18:48:16] Finished a frame (61)
[18:52:28] Finished a frame (62)
[18:56:28] Finished a frame (63)
[19:00:26] Finished a frame (64)
[19:04:30] Finished a frame (65)
[19:08:30] Finished a frame (66)
[19:12:28] Finished a frame (67)
[19:16:27] Finished a frame (68)
[19:20:27] Finished a frame (69)
[19:24:25] Finished a frame (70)
[19:28:24] Finished a frame (71)
[19:32:21] Finished a frame (72)
[19:36:18] Finished a frame (73)
[19:40:16] Finished a frame (74)
[19:44:15] Finished a frame (75)
[19:48:11] Finished a frame (76)
[19:52:10] Finished a frame (77)
[19:56:07] Finished a frame (78)
[20:00:04] Finished a frame (79)
[20:04:02] Finished a frame (80)
[20:07:57] Finished a frame (81)
[20:11:52] Finished a frame (82)
[20:15:45] Finished a frame (83)
[20:19:40] Finished a frame (84)
[20:23:35] Finished a frame (85)
[20:27:32] Finished a frame (86)
[20:31:28] Finished a frame (87)
[20:35:23] Finished a frame (88)
[20:39:19] Finished a frame (89)
[20:43:14] Finished a frame (90)
[20:47:10] Finished a frame (91)
[20:51:05] Finished a frame (92)
[20:55:02] Finished a frame (93)
[20:59:05] Finished a frame (94)
[21:03:04] Finished a frame (95)
[21:07:04] Finished a frame (96)
[21:11:02] Finished a frame (97)
[21:15:01] Finished a frame (98)
[21:19:00] Finished a frame (99)
[21:22:58] Finished a frame (100)
[21:26:58] Finished a frame (101)
[21:30:57] Finished a frame (102)
[21:34:57] Finished a frame (103)
[21:38:56] Finished a frame (104)
[21:42:54] Finished a frame (105)
[21:46:53] Finished a frame (106)
[21:50:54] Finished a frame (107)
[21:54:56] Finished a frame (108)
[21:58:57] Finished a frame (109)
[22:03:00] Finished a frame (110)
[22:07:02] Finished a frame (111)
[22:11:03] Finished a frame (112)
[22:15:04] Finished a frame (113)
[22:19:04] Finished a frame (114)
[22:23:05] Finished a frame (115)
[22:27:08] Finished a frame (116)
[22:31:10] Finished a frame (117)
[22:35:18] Finished a frame (118)
[22:39:18] Finished a frame (119)
[22:43:17] Finished a frame (120)
[22:47:18] Finished a frame (121)
[22:51:17] Finished a frame (122)
[22:55:15] Finished a frame (123)
[22:59:15] Finished a frame (124)
[23:03:17] Finished a frame (125)
[23:07:15] Finished a frame (126)
[23:11:13] Finished a frame (127)
[23:15:12] Finished a frame (128)
[23:19:12] Finished a frame (129)
[23:23:12] Finished a frame (130)
[23:27:13] Finished a frame (131)
[23:31:14] Finished a frame (132)
[23:35:14] Finished a frame (133)
[23:39:15] Finished a frame (134)
[23:43:14] Finished a frame (135)
[23:47:12] Finished a frame (136)
[23:51:10] Finished a frame (137)
[23:55:08] Finished a frame (138)
[23:59:07] Finished a frame (139)
[00:03:05] Finished a frame (140)
[00:07:03] Finished a frame (141)
[00:11:00] Finished a frame (142)
[00:14:56] Finished a frame (143)
[00:18:53] Finished a frame (144)
[00:22:49] Finished a frame (145)
[00:26:44] Finished a frame (146)
[00:30:45] Finished a frame (147)
[00:34:41] Finished a frame (148)
[00:38:37] Finished a frame (149)
[00:42:32] Finished a frame (150)
[00:46:27] Finished a frame (151)
[00:50:25] Finished a frame (152)
[00:54:22] Finished a frame (153)
[00:58:18] Finished a frame (154)
[01:02:13] Finished a frame (155)
[01:06:08] Finished a frame (156)
[01:10:03] Finished a frame (157)
[01:13:58] Finished a frame (158)
[01:17:57] Finished a frame (159)
[01:21:54] Finished a frame (160)
[01:25:52] Finished a frame (161)
[01:29:48] Finished a frame (162)
[01:33:43] Finished a frame (163)
[01:37:39] Finished a frame (164)
[01:41:33] Finished a frame (165)
[01:45:30] Finished a frame (166)
[01:49:27] Finished a frame (167)
[01:53:24] Finished a frame (168)
[01:57:21] Finished a frame (169)
[02:01:19] Finished a frame (170)
[02:05:19] Finished a frame (171)
[02:09:18] Finished a frame (172)
[02:13:18] Finished a frame (173)
[02:17:16] Finished a frame (174)
[02:21:17] Finished a frame (175)
[02:25:21] Finished a frame (176)
[02:29:20] Finished a frame (177)
[02:33:18] Finished a frame (178)
[02:37:15] Finished a frame (179)
[02:41:13] Finished a frame (180)
[02:45:10] Finished a frame (181)
[02:49:09] Finished a frame (182)
[02:53:07] Finished a frame (183)
[02:57:05] Finished a frame (184)
[03:01:03] Finished a frame (185)
[03:05:01] Finished a frame (186)
[03:08:59] Finished a frame (187)
[03:12:55] Finished a frame (188)
[03:16:52] Finished a frame (189)
[03:20:49] Finished a frame (190)
[03:24:45] Finished a frame (191)
[03:28:41] Finished a frame (192)
[03:32:38] Finished a frame (193)
[03:36:36] Finished a frame (194)
[03:40:33] Finished a frame (195)
[03:44:31] Finished a frame (196)
[03:48:30] Finished a frame (197)
[03:52:29] Finished a frame (198)
[03:56:27] Finished a frame (199)
[04:00:23] Finished a frame (200)
[04:04:19] Finished a frame (201)
[04:08:19] Finished a frame (202)
[04:12:14] Finished a frame (203)
[04:16:12] Finished a frame (204)
[04:20:07] Finished a frame (205)
[04:24:02] Finished a frame (206)
[04:27:57] Finished a frame (207)
[04:31:53] Finished a frame (208)
[04:35:49] Finished a frame (209)
[04:39:44] Finished a frame (210)
[04:43:39] Finished a frame (211)
[04:47:35] Finished a frame (212)
[04:51:30] Finished a frame (213)
[04:55:25] Finished a frame (214)
[04:59:22] Finished a frame (215)
[05:03:20] Finished a frame (216)
[05:07:17] Finished a frame (217)
[05:11:17] Finished a frame (218)
[05:15:16] Finished a frame (219)
[05:19:15] Finished a frame (220)
[05:23:14] Finished a frame (221)
[05:27:11] Finished a frame (222)
[05:31:09] Finished a frame (223)
[05:35:08] Finished a frame (224)
[05:39:07] Finished a frame (225)
[05:43:11] Finished a frame (226)
[05:47:08] Finished a frame (227)
[05:51:04] Finished a frame (228)
[05:55:02] Finished a frame (229)
[05:59:00] Finished a frame (230)
[06:03:00] Finished a frame (231)
[06:07:00] Finished a frame (232)
[06:10:58] Finished a frame (233)
[06:14:57] Finished a frame (234)
[06:18:55] Finished a frame (235)
[06:22:52] Finished a frame (236)
[06:26:51] Finished a frame (237)
[06:30:48] Finished a frame (238)
[06:34:46] Finished a frame (239)
[06:38:43] Finished a frame (240)
[06:42:41] Finished a frame (241)
[06:46:38] Finished a frame (242)
[06:50:34] Finished a frame (243)
[06:54:33] Finished a frame (244)
[06:58:31] Finished a frame (245)
[07:02:52] Finished a frame (246)
--- Opening Log file [April 17 07:07:15]
Arguments: -service
[07:07:16] - Ask before connecting: No
[07:07:16] - User name: Rebel Alliance (Team 0)
[07:07:16] - User ID = 4FDA1091029525C6
[07:07:16] - Machine ID: 1
[07:07:16]
[07:07:16] Loaded queue successfully.
[07:07:16] + Benchmarking ...
[07:07:18]
[07:07:18] + Processing work unit
[07:07:18] Core required: FahCore_65.exe
[07:07:18] Core found.
[07:07:18] Working on Unit 06 [April 17 07:07:18]
[07:07:18] + Working ...
[07:07:19] Folding@Home Client Core Version 2.47 (June 14, 2002)
[07:07:19]
[07:07:19] Proj: work/wudata_06
[07:07:19] Done: 24459 -> 148247 (decompressed 606.1 percent)
[07:07:19] nsteps: 2000000 dt: 2.000000 dt_dump: 100.000000 temperature: 323.000000
[07:07:19] xyzfile:
[07:07:19] " 473 p659_1PRB_NAT
[07:07:19] 1 CH3 8.775540 4.032773 -18.164073 7 ..."
[07:07:19] keyfile:
[07:07:19] "parameters ./proj659.prm
[07:07:19] NOVERSION
[07:07:19] ARCHIVE
[07:07:19]
[07:07:19] cutoff 16.0
[07:07:19] taper 12...."
[07:07:19]
[07:07:19] Hashes matched on file work/wudata_06.dyn
[07:07:22] ARC file integrity verified
[07:07:22] Restarting from checkpointed files.
[07:07:22]
[07:07:22] Protein: p659_1PRB_NAT
[07:07:22] - Run: 11 (Clone 36, Gen 1)
[07:07:22] - Frames Completed: 246, Remaining: 154
[07:07:22] - Dynamic steps required: 770000
[07:07:22]
[07:07:22] Writing local files:
[07:07:22]
[07:07:22] parameters work/wudata_06.prm
[07:07:22] - Writing "work/wudata_06.key": (overwrite) successful.
[07:07:23] - Writing "work/wudata_06.xyz": (overwrite) successful.
[07:07:23] - Writing "work/wudata_06.prm": (overwrite) successful.
[07:07:23] - Writing "work/wudata_06.key": (append) successful.
[07:07:23]
[07:07:23] PROJECT="work/wudata_06", NSTEPS=770000, DT=2.0000, DTDUMP=10.000000, TEMP=323.00
[07:07:24] TINKER: Software Tools for Molecular Design
[07:07:24] Version 3.8 October 2000
[07:07:24] Copyright (c) Jay William Ponder 1990-2000
[07:07:24] portions Copyright (c) Michael Shirts 2001
[07:07:24] portions Copyright (c) Vijay S Pande 2001
[07:11:26] Finished a frame (247)
[07:15:28] Finished a frame (248)
[07:19:28] Finished a frame (249)
[07:23:34] Finished a frame (250)
[07:27:33] Finished a frame (251)
[07:31:30] Finished a frame (252)
[07:35:27] Finished a frame (253)
[07:39:27] Finished a frame (254)
[07:43:25] Finished a frame (255)
[07:47:20] Finished a frame (256)
[07:51:16] Finished a frame (257)
[07:55:13] Finished a frame (258)
[07:59:09] Finished a frame (259)
[08:03:05] Finished a frame (260)
[08:06:57] Finished a frame (261)
[08:10:52] Finished a frame (262)
[08:14:49] Finished a frame (263)
[08:18:46] Finished a frame (264)
[08:22:44] Finished a frame (265)
[08:26:42] Finished a frame (266)
[08:30:42] Finished a frame (267)
[08:34:40] Finished a frame (268)
[08:38:37] Finished a frame (269)
[08:42:35] Finished a frame (270)
[08:46:33] Finished a frame (271)
[08:50:35] Finished a frame (272)
[08:54:32] Finished a frame (273)
[08:58:29] Finished a frame (274)
[09:02:28] Finished a frame (275)
[09:06:28] Finished a frame (276)
[09:10:26] Finished a frame (277)
[09:14:25] Finished a frame (278)
[09:18:27] Finished a frame (279)
[09:22:27] Finished a frame (280)
[09:26:27] Finished a frame (281)
[09:30:29] Finished a frame (282)
[09:34:29] Finished a frame (283)
[09:38:28] Finished a frame (284)
[09:42:26] Finished a frame (285)
[09:46:27] Finished a frame (286)
[09:50:26] Finished a frame (287)
[09:54:25] Finished a frame (288)
[09:58:25] Finished a frame (289)
[10:02:25] Finished a frame (290)
[10:06:25] Finished a frame (291)
[10:10:25] Finished a frame (292)
[10:14:26] Finished a frame (293)
[10:18:25] Finished a frame (294)
[10:22:24] Finished a frame (295)
[10:26:24] Finished a frame (296)
[10:30:23] Finished a frame (297)
[10:34:21] Finished a frame (298)
[10:38:24] Finished a frame (299)
[10:42:21] Finished a frame (300)
[10:46:18] Finished a frame (301)
[10:50:15] Finished a frame (302)
[10:54:16] Finished a frame (303)
[10:58:17] Finished a frame (304)
[11:02:18] Finished a frame (305)
[11:06:19] Finished a frame (306)
[11:10:20] Finished a frame (307)
[11:14:23] Finished a frame (308)
[11:18:24] Finished a frame (309)
[11:22:23] Finished a frame (310)
[11:26:25] Finished a frame (311)
[11:30:26] Finished a frame (312)
[11:34:26] Finished a frame (313)
[11:38:26] Finished a frame (314)
[11:42:26] Finished a frame (315)
[11:46:26] Finished a frame (316)
[11:50:25] Finished a frame (317)
[11:54:25] Finished a frame (318)
[11:58:25] Finished a frame (319)
[12:02:26] Finished a frame (320)
[12:06:24] Finished a frame (321)
[12:10:22] Finished a frame (322)
[12:14:21] Finished a frame (323)
[12:18:20] Finished a frame (324)
[12:22:21] Finished a frame (325)
[12:26:24] Finished a frame (326)
[12:30:24] Finished a frame (327)
[12:34:27] Finished a frame (328)
[12:38:28] Finished a frame (329)
[12:42:30] Finished a frame (330)
[12:46:30] Finished a frame (331)
[12:50:28] Finished a frame (332)
[12:54:25] Finished a frame (333)
[12:58:23] Finished a frame (334)
[13:02:21] Finished a frame (335)
[13:06:19] Finished a frame (336)
[13:10:18] Finished a frame (337)
[13:14:18] Finished a frame (338)
[13:18:18] Finished a frame (339)
[13:22:18] Finished a frame (340)
[13:26:17] Finished a frame (341)
[13:30:13] Finished a frame (342)
[13:34:10] Finished a frame (343)
[13:38:08] Finished a frame (344)
[13:42:09] Finished a frame (345)
[13:46:11] Finished a frame (346)
[13:50:22] Finished a frame (347)
[13:54:39] Finished a frame (348)
If you check the first few lines for each start session, you will see that this machine didn't get assigned to a team
Stop all work on that machine, and manually re-run the client, giving it a -config option. Make sure you put in team 198 for the
team, and your data should start showing up under Josh's stats. I believe that this will NOT disturb your work in progress, and
it should resume processing where you stopped.
First off Thanks! I'm a noob at F&H😱
This certainly doesn't look right! Team 0?
All machines are configured as Rebel Alliance NOT Rebel_Alliance
I am running the cli and have it installed as a service, I'm not sure how to do this.
Once you have stopped the service, you can do various things through the command line:
First thing is to open a command prompt/dos window
cd <fah folder>
to set up the configuration:
FAH3Console -config
to look at your queue information
FAH3Console -queueinfo
to send your WUs
FAH3Console -send x where x = queue # or all for all
to see all the other options available
FAH3Console --help
I am not sure what is really your problem, but as I can see for your log file, you didn't desire a team number in that machine.
Here your log file
I checked stat for you and I found your score for both "Team #198 (AT) score 1398.96 " and "No team designation score 772.72" Is this the one we are talking about?
Here your log file
I believe this is the problem!
OK I think I have this fixed. I started out using the GUI on folding and had problems with it hanging and not working on the work units. Then I went to the cli and finally installed it as a service. Obviously the service install worked fine but for some reason my team number didn't take with it.
Long story short, there were bits and pieces of F@H all over this machine so I just completely removed everything related to F@H including removing the service and started over fresh.
Everything looks to be in order now!
Thanks everyone for the help!!!!
