F@H-can't get workunit problem
Thump553
12,839
2,625
I've been running F@H on this box for a year or more now without a problem, but starting about two hours ago my main F@H cannot get a workunit. Surprisingly the graphics unit I'm running on the same box has gotten at least one workunit in that time.
I've rerun the configonly setup and rebooted the box. It's trying to get units from http://assign.stanford.edu:8000, it connects but then says "no appropriate work server was available, will try again in a bit" and "cannot get work instructions."
Is this a problem at my end or at Stanford's?
ICXRa
5,924
My main rig at the house uploaded a completed work unit a couple hours ago, and is having the same problem. We will just have to wait until the work unit server issue is corrected.
Thump553
12,839
2,625
Mine finally got through a little while ago, but it took about six hours.
Thump553
12,839
2,625
Necroing an old thread, but I'm having this exact same problem again-for 2+ days now. Can't get a work unit on my cpu cruncher, the gpu cruncher on the same box is doing fine. Here is the log:
# Windows CPU Console Edition #################################################
Folding@Home Client Version 6.29
http://folding.stanford.edu
Launch directory: C:\FAH
Executable: C:\FAH\FAH6.exe
Arguments: -verbosity 9
[09:33:29] - Ask before connecting: No
[09:33:29] - User name: Thump553 (Team 198)
[09:33:29] - User ID: 7725D0634B79FF0B
[09:33:29] - Machine ID: 1
[09:33:29]
[09:33:29] Loaded queue successfully.
[09:33:29] - Preparing to get new work unit...
[09:33:29] Cleaning up work directory
[09:33:29] - Autosending finished units... [February 8 09:33:29 UTC]
[09:33:29] Trying to send all finished work units
[09:33:29] + No unsent completed units remaining.
[09:33:29] - Autosend completed
[09:33:29] + Attempting to get work packet
[09:33:29] Passkey found
[09:33:29] - Will indicate memory of 3071 MB
[09:33:29] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 6, Stepping: 2
[09:33:29] - Connecting to assignment server
[09:33:29] Connecting to http://assign.stanford.edu:8080/
[09:33:30] Posted data.
[09:33:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:33:30] + Couldn't get work instructions.
[09:33:30] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[09:33:48] + Attempting to get work packet
[09:33:48] Passkey found
[09:33:48] - Will indicate memory of 3071 MB
[09:33:48] - Connecting to assignment server
[09:33:48] Connecting to http://assign.stanford.edu:8080/
[09:33:48] Posted data.
[09:33:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:33:48] + Couldn't get work instructions.
[09:33:48] - Attempt #2 to get work failed, and no other work to do.
[09:34:11] + Attempting to get work packet
[09:34:11] Passkey found
[09:34:11] - Will indicate memory of 3071 MB
[09:34:11] - Connecting to assignment server
[09:34:11] Connecting to http://assign.stanford.edu:8080/
[09:34:11] Posted data.
[09:34:11] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:34:11] + Couldn't get work instructions.
[09:34:11] - Attempt #3 to get work failed, and no other work to do.
[09:34:45] + Attempting to get work packet
[09:34:45] Passkey found
[09:34:45] - Will indicate memory of 3071 MB
[09:34:45] - Connecting to assignment server
[09:34:45] Connecting to http://assign.stanford.edu:8080/
[09:34:46] Posted data.
[09:34:46] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:34:46] + Couldn't get work instructions.
[09:34:46] - Attempt #4 to get work failed, and no other work to do.
[09:35:36] + Attempting to get work packet
[09:35:36] Passkey found
[09:35:36] - Will indicate memory of 3071 MB
[09:35:36] - Connecting to assignment server
[09:35:36] Connecting to http://assign.stanford.edu:8080/
[09:35:36] Posted data.
[09:35:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:35:36] + Couldn't get work instructions.
[09:35:36] - Attempt #5 to get work failed, and no other work to do.
[09:37:10] + Attempting to get work packet
[09:37:10] Passkey found
[09:37:10] - Will indicate memory of 3071 MB
[09:37:10] - Connecting to assignment server
[09:37:10] Connecting to http://assign.stanford.edu:8080/
[09:37:11] Posted data.
[09:37:11] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:37:11] + Couldn't get work instructions.
[09:37:11] - Attempt #6 to get work failed, and no other work to do.
[09:39:53] + Attempting to get work packet
[09:39:53] Passkey found
[09:39:53] - Will indicate memory of 3071 MB
[09:39:53] - Connecting to assignment server
[09:39:53] Connecting to http://assign.stanford.edu:8080/
[09:39:53] Posted data.
[09:39:53] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:39:53] + Couldn't get work instructions.
[09:39:53] - Attempt #7 to get work failed, and no other work to do.
Ken g6
Moderator
Dec 11, 1999
16,836
4,816
75
Have you considered updating to the V7 client?
Thump553
12,839
2,625
V7 client seems to have done the trick. Haven't really kept up with FAH and the earlier version is what I installed way back when I got this computer. I wonder how many copies of FAH are out there not running properly because people don't proactively look after them?
ICXRa
5,924
FWIW I had the same problem on my Q9550 cruncher. Shut it down, dump the work, queue.dat, and unitinfo folders and fire back up. Worked like a charm.
I noticed my work unit hung at 100%, so probably lost that one.
I still running SMP instead of V7 on all my multicore rigs, which includes many dual cores. I'm concerned switching to V7 will cause them not produce as well, is this warranted?
