- Feb 7, 2011
- 29
- 0
- 0
Question for those running Eyefinity at mixed resolution. More specifically, different resolutions with the same sized monitors. I've seen examples, but all of them are mixed sized monitors.
Looking to add 1080p monitors to my 1440p (on its way). I still plan to mostly game on the 1440p, but for flight sims and racing, 5760x1080 is awesome.
The middle monitor will be a 27' 1440p 144hz. I can get two 27 1080p monitors fairly cheap on CL. Anyone running a similar setup? I've seen where smaller monitors can be adjusted to match the middle, or vice versa, but not sure how the middle will scale to match the same sized screen.
I wish I had one to try before I buy. I just cant seem to find examples of this setup. Most examples are just mismatched monitors of different sizes, where Eyefinity will just chop the top off the higher resolution and run 5760x1080, etc. With monitors being the same size, no chopping will be possible. Perhaps 24" 1080ps on the side will scale better?
Thanks for any help, comments, advice!
