Originally posted by: Naustica
Take a break and get a breath of fresh air.
Originally posted by: niggles
Anyone suffer with eye spasms when working in front of your PC? Someone here is telling me that this may be related to the monitor. I have my monitor set to 85hrz on refresh rate. Shouldn't that be ok?
This is very true and quite common. Get the newest drivers for your monitor, and choose 60hz, then go back up to 85hz just to make sure it's actually 85hz.Originally posted by: Jaxidian
Are you certain that the monitor is actually running at 85Hz? I've seen Windows say that your display is running at a higher refresh rate than it really is. In those cases, the default refresh rate is typically 60Hz.
Originally posted by: MonkeyDriveExpress
If this truly screws with your eyes, you could feasibly have your employer get you an LCD or a better CRT (higher refresh rates).
Its the refresh rate, if you don't like it. Get a LCD, I switched and will never go back.
Its quite possible that your employer is legally obliged to provide a generally safe working environment. Taking care of your eyes should be a part of Health and Safety. Also, you are supposed to take a 10-15 min break per hour at the computer, if they sack you for doing this.... there should be laws to protect your own interests.
10-15 per hr break, that means up to 2hrs break time in an 8 hr day. They could fire you for being unproductive.
Pc's have been in the work force since the 1980's, the screen quality has never been better. Find the root cause of your flickering, it may very well be a simple fix.
I agree,switching to LCD is better for your eyes 🙂.
