wwswimming
Banned
check out this pink teapot
http://www.geocities.com/wwswimming/max-question.jpg
the extrude edges feature was presented in a George Maestri
tutorial i watched.
it looks like it's extruding normal to the surface, though that
might be related to the start geometry.
each successive extrude appears to create a face at a
right angle. if you do 4 in a row of the same amplitude,
it looks like you end up back where you started.
is there a way to alter the "handedness" of the extrusion-from-edge
feature, or does it always "sort of behave the same" ?
