Extremely thin mouse pads = what's best
Ordskii
27
Hi All. I like really thin mouse pads. Any of you use a paper thin variety you like?
I have been happy with 3ms precise surface and an Xtrac pro - both good but the Xtrac is a bit thick (high) for my liking.)
Thanks.
NoelS
566
Thanks.
Ordskii,
I use a cordless mouse with my laptop and never use a mouse pad. Just whatever decent surface is available - like now I'm using my table cloth while having coffee. In the evening I sit in an easy chair and use the chair's fabric covering, with laptop where it belongs - in my lap :)
If you really feel you need a pad, I'd go with Sheninat0r's suggestion. Try cheap first and if it works, there you go...
Noel
Zepper
18,998
Well, the black and blue pads mentioned above are designed for different mouse tech: one is for laser mice (black) the other is for optical mice (blue). What'll they think of next - tech specific mouse pads... :roll:
.bh.
Apr 29, 2007
175
.bh.
which is odd because laser mice track bad on black surfaces and red sensor mice track bad on blue surfaces. tech specific mouse pads already exist - i have one.
Epic22
61
I don't use a mouse pad. It just sits on my table..I should get one soon though
zig3695
1,240
the black one works with standard optical mice just as good. i have bought four of these pads now, they are TOPS. trust me
TehBluebear
17
Heh, A4 peice of paper for me. I'm on the student life, can't be wasting money on mousepads, can I? :p
Nomadic
Go in for steel series or everglide. they are best in gaming mousepads. And I am not kidding.
jdkick
601
I also use a Func pad and have been quite happy with it. It's been nearly three years and continues to wear very well.
Amberion
I use a hardcover book with a silver color. The only gripe I have is that it's a relatively thick-ish book and working for long periods can strain my wrist. :/
zig3695
1,240
Originally posted by: DJCrunkMix
Get the black laser mouse pad from Walmart. As mentioned above, this one: http://www.handstands.com/reta...big_laser-mousepad.jpg
Its cheaper than CompUSA if you buy it from Walmart. I got mine for 5$.
As far as the mouse pad is concerned, its great. Works as advertised :D.
awesome info. people have no idea how good these pads are. they perform as good as any ive tried, and they even look and feel great.
