PC turns on a for a few seconds then cuts off. Changed power supply. Computer works unless two rear fans are plugged in. Swapped rear fans out for two different fans. Computer behaves the same way, cuts on then off. If I leave fans unplugged the computer will stay on.
I'm thinking that at this point I have a bad case or a bad motherboard, with the most likely culprit being the motherboard perhaps giving up at a certain voltage level.
Any thoughts??
